Question about NetGear PS121 Print Server
Can't get Netgear PS121v2 to work on my laptop
I installed this server successfully on my Desktop PC for my HP DeskJet F2100. However, when trying to set the server up on my Laptop I get a message that says it was not able to download successfully. I'm not sure why. My printer shows up, I click on it, the set up wizard starts downloading the driver and then after a few minutes I get the above message and it also tells me to restart the computer and try again. I've tried it several times and nothing. Please help!!! :o/
  • Computer v9 Jul 13, 2008
    i get the same thing i can see the printer if i go to add printer but it does not conect to it.
  • bncsenn Oct 03, 2008
    I can install the driver software but it does not stay resident, it does not show up on the tool bar, nor does it show up in the installed software list. All of this happened after Vista did an upgrade. It worked fine before that.
I finally figured it out myself. The problem is that when you uninstall the print server software, it does not do it correctly. I used regedit to manually remove the server software and reinstalled, and all is well. Hope this helps.
Posted on Nov 02, 2008
You need to create a new Port rather than using an existing port for adding a new printer. You will need to know the IP address of the PS121 print server BEFORE you start this (you will need to enter this information manually). New port type that worked for me was: Standard TCP/IP Port.
Netgear ps121v2 Smart Wizard does not appear
If you are running WIndows 7 64 bit, you need to run the 64 bit version of the installer. Look in the directory ...\bin\driver\MFP\Utilityx64
Also in, Windows 7 you need to run the install wizard as administrator, since it is installing drivers.Right click on SetupWizard.exe and select "Run As Asministrator".
Jan 19, 2013 | NetGear PS121 Print Server
I cant install the driver of HP Deskjet F2100 series, HP Deskjet F4100 series printer to my new PC which is Windows 7
Are you trying to use the CD? If so go to HP.com/support and see if there are Windows 7 drivers available for the printer (be sure to note whether you have 32 or 64-bit Windows 7).
Feb 06, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Setup with a netgear print server
Be sure you have it setup correctly and the IP address is correct. Also you may want to check with Netgear on whether or not that model is compatible with Bi-Directional printers.
Jan 13, 2010 | HP Deskjet 5440 InkJet Photo Printer
PS121v2 does not install successfully
Check if your printer has been mentioned in the compatibility list:
http://kb.netgear.com/app/answers/detail/a_id/137
Aug 05, 2009 | NetGear PS121 Print Server
Can't install software for HP Deskjet F2100
I DONT HAVE CD FOR MI HP DESKJET F2100 HAW I CANT INSTAL DRIVERS
Jul 18, 2008 | HP Office Equipment & Supplies
One page wasted before print out
Hi Ontheedge,
I really hate suggesting it is a Netgear issue, and dump it, Edge, but most of the posts I found on that Print Server is not good. I would check for a setting in the Manger software, but not sure where it is. These link suggest it is a Netgear issue.
http://forum1.netgear.com/showthread.php?t=17002
Dec 20, 2007 | NetGear PS121 Print Server
Deskjet f2100 series
what kind of software did you use or did you just install the printer with the computer drivers i need more info about this problem
Dec 17, 2007 | HP PSC 1610 All-In-One InkJet Printer
Hp deskjet f2100 problem
I have down loaded a HP Deskjet All in one F2100 to my computer The printer is working but not the scanner can you help me
Nov 12, 2007 | HP PSC 1610 All-In-One InkJet Printer
NetGear PS121 Print Server Logo
1,648 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
