Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
Blue light clicking noise
I used to be ble to connect my Store Jet to the computer and read it properly. Now that i plug it in, the light that used to turn green, is blue, and makes a annoying clicking noise. AS well as it is not recognized by my CPU
  • purpleamara Aug 18, 2008
    Kind of the same problem. The light is orange but it's clicking as if it's really 'trying'. My new PC won't recognise it at all and I'm gutted incase I lose all the stuff on it, like pics of my daughter and stuff.
    Problem Solver:
  • 8 Answers
This is known as the "click of death" among hard drives. Your external is merely a normal hard drive in an enclosure, and just as the hard drive in your computer can crash, so an the one in the enclosure, especially since it they tend to be transported a lot more. The sound you hear is the head seeking rapidly back and forth across the platters, and it isn't seeing anything.
I read the manual, and it doesn't say anything about a blue light. If the information is vitally important, there are companies that do data recovery that you can find, but it will run you upwards of $300. If it's not that important to you, buy a new hard drive and treat it nicely.
Posted on Apr 02, 2008
Have a Peugeot Jet Force 125 and it turns over but no spark in plugs
Hi, Don and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Peugeot jet force 50cc No spark
GY6 Electrical Troubleshooting Tutorial No Spark Eliminator
Peugeot JET FORCE 125 cc 2003 Parts
PEUGEOT JETForce Technical Training Manual
May 21, 2017 | Peugeot Motorcycles
Blue light not staying on
You understand the drive does nothing by itself? It is your computer that uses the drive. If the computer is not connected properly then nothing can happen. Check the cable (substitute a different cable), try a different connector on the computer.
If all else fails you can take it to the store you bought it from (or a store that sells your product) and have a technician test your drive.
Mar 13, 2014 | LaCie Computers & Internet
Fix ruff idle on 2005 -1700 Yamaha Midnight Star
Hi, Elmer and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
9. Multi carburetors out of sync and need to be balanced.
Rough Idle and Engine Noise
Deceleration rough idle while cold
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Jul 07, 2012 | 2005 Yamaha Road Star Silverado
My new asus n73s will not play ble-ray. Is the problem with the slimetype BD E DS4E1S. Best regards from Bottolf Loedemel
Go to my computer, right click the Blue Ray drive, click properties, click enable and update driver, click apply and save.
Aug 20, 2011 | Computers & Internet
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
It doesn't turn on!
If your Macintosh computer won't turn on, here's how to troubleshoot it. Please keep in mind that although your computer may display similar symptoms that prevent it from showing video, this article discusses what to do if the computer won't turn on, meaning that when you press the power button:
  • You don't hear a startup chime
  • You don't hear any fan or drive noise
  • The power button or power indicator doesn't light up at all
If your computer doesn't display any video, it may display one or more of these similar symptoms when you press the power button:
  • You may hear a startup chime
  • You may hear fan or drive noise
  • You may see the power button or power indicator light up
If any of these conditions occurs, see the Troubleshooting: My computer has no video article instead. If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU or PRAM.
    • For a portable (iBook or PowerBook), click here for instructions.
    • For a Mac mini, click here.
    • For an iMac, click here.
    • For a Power Mac, click here.
    • For a Mac Pro click here.
    • For a MacBook or MacBook Pro, click here.
    • For any other computer, click here for instructions on resetting the PRAM.
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
Feb 22, 2008 | M-Audio US85100 Keyboard
Light blue is on, Seems it doesn't start at all
Check it on a second computer, if the problem follows the drive, then the drive is defective. You could take the case apart, and make sure the cabling is properly seated. Have seen an external drive where the interface cable (to the drive itself) was not properly seated, and resulted in a non-working unit.
Sep 12, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
923 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
John Porter
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
