1998 Ford Escort Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trouble finding the tensioner pulley on my 1998 ford escort zx2
Where is the serpentine belt tensioner pulley on a 1998 ford escort zx2?
Anonymous
Level 3:
  • Master 3,489 Answers
  • Posted on May 19, 2010
Anonymous
Master
Level 3:
Answers
3489
Questions
0
Helped
1160057
Points
10709
Email me at [email protected] and I can get a diagram to you so you know exactly what you are looking for under the hood.
2answers
Serpentine belt diagram 2002 Ford escort zx2
The picture is for a zetec. Let me know if wrong diagram?
How to put a serpentine belt on a ford zx2 4 cylinder
The serpentine drive belt on a Ford Escort ZX2 snakes its way from the crankshaft pulley out to the engine accessory pulleys and the serpentine belt tensioner. The serpentine belt system's design employs only one belt, held taught with the automatic belt tensioner, eliminating the need for the multiple belt system used on earlier model year Escorts. When the belt begins cracking, fraying or losing ribs, it's time to replace it. If you have entry-level auto-repair skill, you can change a belt on a Ford Zx2 in about 45 minutes. http://www.lightdeal.co.uk
Cannot find belt tensioner on 2001 ford escort
  • Locate the serpentine belt tensioner on the front of the engine. The belt tensioner on the 2001 Ford Escort is located directly under the power steering pump and above the air conditioner pump. The belt tensioner has a 17 mm bolt head in the center of the pulley.
  • 1helpful
    How to replace a zx2 serpentine belt
    Click on the following free direct Link. It has the correct Serpentine/Drive Belt Diagrams for your 1998 Ford Escort ZX2, 2.0L DOHC In-Line 4-Cylinder Engine.
    The Link says 2000 for the Year, however this is the same as the 1998 Year Model.
    http://www.2carpros.com/car_repair_information/year/2000/make/ford/model/zx2/2000_ford_zx2_drive_belt_routing_diagram.htm
    "HOW TO":
    Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
    1. Find the Tensioner(s). (See Diagrams on Link)
    2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
    3. Remove the loosened belt off one of the other more easily accessed Pulleys.
    4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
    Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
    a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
    b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
    c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
    d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
    e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
    Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
    13helpful
    2answers
    Need belt diagram for a 1998 ford escort zx2
    Here it is. 13mm wrench to rotate tensioner
    Need 2001 ford escort zx2 DOHC engine information, belt diagrams
    The tensioner is between the a/c compressor and crank pulley, below the power steering pump. Use a 13 mm wrench to 'tighten' the bolt in the center of the pulley and it'll move to release tension off the belt.
    1helpful
    Serpentine belt installation on an 1998 ford ZX2 escort
    If there is no diagram on the underside of your hood, or around the engine compartment, just wrap it around the crankshaft, and work your way around the pulleys, going flats to flats, ribs to ribs. There may be a couple of combinations, but you'll get it.
    11helpful
    Belt routing diagram 98 zx2 2.0
    1) Start with the alternator.
    2) Forward to the smooth idler
    3) Forward to power steering
    4) Down to A/C compressor
    5) Back to crank pulley
    6) Forward around tensioner
    7) Back glancing off of water pump
    8) Back glancing off of ribbed idler
    9) Up around alternator (where you started)
    2helpful
    3answers
    I need a diagram for a serpentine belt for a 1999 ford escort zx2
    This information can be found at www.serpentinebeltdiagram.com
    They have all the belt routing info for any vehicle with a serpentine belt.
    Hope this helps....
    Top Ford Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    xxxxxx xxx
    Are you a Ford Expert? Answer questions, earn points and help others
