Question about Nintendo Wii Console
Controller moving in the oppisite direction
I keep on resetting my controller yet it keeps moving in the oppisite diretion of my hand motion
    Scholar:
  • 119 Answers
You're holding the controller with the black part facing toward your TV, right?
Also make sure there are strong light sources in the same direction as your TV. This can sometimes confuse the Wii remote.
Posted on Apr 05, 2008
My motion security light keeps blowing only the left side bulb.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
I recently moved my melodies in motion clock back one hour for daylight savings time and now the clock is not keeping time. I suppose I should not have moved it backwards but now what do I do to get the...
By moving the clock back one hour you changed from DST to standard time, not as you stated. Some clocks require you to rotate the hands clockwise to set the time back. Your clock may have been damaged beyond repair.
Nov 05, 2013 | Seiko Melodies in Motion Clock
Hi I have a meade ETX 105 pe I can get the scope to move Alt motion with the controller but it wont move in the Azimuth position with the controller. Might I be doing something wrong
This can be caused by 4 things-
A stuck button on the hand controller.
A bad hand controller cable
A burned out circuit board inside
A burned out Azimuth motor
(Long shot) bad firmware in the hand controller. DO a Reset and reload the firmware.
Try to borrow another hand controller and buy a new cable. If these two do not fix it then it's a mechanical problem or a circuit board problem inside the scope.
Meade can repair this but you will need to send them the scope:
http://www.meade.com/support/index.html
Mar 26, 2011 | Meade ETX-105AT (420 x 105mm) Telescope
If the watch is not worn for a day, is it normal for it to stop or slow down? Vintage SS mens datejust, oyster perpetual.
mcdevito75 here, Yes it is normal, especially if your Rolex is an automatic watch. The motion of your Wrist / Hand keeps your watch wound thru the Counter balance on the movement, as the counter balance turns it winds the mainspring little by little, thus keeping your watch wound. Once you take off your watch, if long enough the mainspring simply un-winds and slows and will eventually stop your watch completely. You can keep your Rolex wound even when you take it off by means of a watch winder, a small machine that will keep your watch in motion, or by hand, by rocking the watch back and firth in your hand for about 30 seconds, say before you gpo to bed at night, this way there is always some wind to your watch.
Aug 15, 2010 | Rolex Datejust SS
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Emporio armani 4211
mcdevito75 here, There are 2 ways to wind your Armani Emporio watch, I'm figureing it"s an automatic watch, on some automatics you can start an initial ticking by winding the stem in any direction, if when you wind the stem you feel any resistance then this is the type of automatic watch you Start with about 20--30 winds of the watch. If on the other hand when winding the stem feels very loose and free, no resistance at all, then this is the type of automatic that relize on pure wrist and arm motion to start ticking, simply hold the watch in your hand and make small circle motions, or rocking motion, you should detect something moveing inside the watch, this is the winding counter balncer it's normal, rock or circle the watch for approx. 30 seconds to get it started. In both cases, after the watch starts, the motion of your wrist / arm keeps it wound as you wear it.
Jul 10, 2010 | Giorgio Armani Emporio Armani watches...
I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
Feb 20, 2010 | Sewing Machines
Err 22 keeps displaying on control panel on one treadmill and on another err45 ..... Any answers? Plus some treadmills same to just trip, have to keep switch them back on!
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started
Possible Causes 1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. 2. Drive motor brushes are bad. 3. The speed sensor position relative to the speed sensor target is incorrect. 4. The speed sensor potentiometer adjustment is incorrect (when equipped). 5. The speed sensor is inoperative. 6. The lower PCA is bad. 7. The lower PCA to upper PCA interconnect cable is bad. 8. The upper PCA is bad
Error 45 :The lift control system has detected that the lift is moving in the opposite direction of the issued
Possible Causes 1. Lift Motor hysteresis. 2. Bad lower PCA
Possible Remedies 1. This error would typically happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift up) was issued. Some motors exhibited a very long turn around time and the lift motor would still be moving in the original direction (downward) while the control system was attempting to move the lift in the opposite direction. If the error 45 condition is persistent, replace the lift motor. 2. This is a very rare condition, if the lift moves in the opposite direction of the issued lift command, replace the lower PCA lift command.
Feb 02, 2010 | Precor C954i Commercial Treadmill
Top part of agitator is loose and wobbles and
These are called "dogs" and they are replaceable and do not cost much. Basically, they keep the agitator locked in position when the shaft moves in an oppisite direction so the agitator can step forward.
They should be fairly simple to remove with a phillips screwdriver or a 1-4 in nut driver. take them to a reputable appliance parts store and they will be able to sell you replacements.
These are made to wear out and be replaced so the agitator itself doesnt wear, which is a whole different story to replace. Left-handed shaft screw. Undo it in a clockwise direction and slide the agitator off the shaft if you find that replacing the dogs does not work.
Oct 01, 2009 | Whirlpool Washing Machines
Nintendo Wii Console Logo
64 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
