How do i hook my compter to my tv - Computers & Internet
    Novelist:
  • 125 Answers
Im assuming here you have a new LCD TV with High Definition
if you have a new LCD TV most of them come with either a HDMI input or a 15pin VGA input , if you computers graphics card doesn't have a HDMI output on the graphics card you can use a male to male VGA cable , they are used on most PC LCD screens if you don't need it , 15pin VGA cables usually have blue plugs and have 15 pins :) or you could go to an electronic store and ask for a male to male VGA cable.
once you get the pc conencted to the tv ,
1. right click on the desktop
2. click properties
3. click on the settings tab
from here you can change the resolution and make the TV look decent.
i hope this helps you :)
Posted on Apr 02, 2008
Dont have the remote or the book cant change the settings on the menu to work the dvd player or hook it to my computer
press the "input" or the "source" button on the TV until it changes to your dvd player or compter
Mar 06, 2011 | Televison & Video
I would like to use my old 40 gb Western Digital Harddrive for a secondary data drive on my Desktop computer. When I hooked them both up and powered up the computer wouldn't boot, I assumed it was because...
http://www.lyberty.com/tech/hard_drives/WD_Caviar_WD400BB_specs/index.html
Above is the link to set the jumper on the 40GB to Slave.
Also, before it boots, try to get into the BIOS setting and make sure your compter can see both drives. If not, double check jumper settings for both drives. Turn off compter and change settings.
When computer can see both drives in BIOS, save it and let the compter continue to boot.
Hope this helps.
Jan 04, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
I hooked up a compter to rgb-pc port and selected rgb-pc input and started computer the display comes up ok then it says invalid format how can i fix this russellwidmark@aol.com
CHECK YOUR GRAPHICS CARD DISPLAY PROPERTIES IE:
REFRESH RATE FREQUENCY 55HZ 75HZ ETC. YOUR TV MAY ONLY WORK WITH THE CORRECT REFRESH RATE AND COLOUR RATE CHECK YOUR USER TV MANUAL FOR SETTINGS
Aug 25, 2010 | LG 32LG30 32 in. LCD HDTV
On how long you charge the battery
I charge mine when I go to bed, I  leave it hooked up to the compter till morning.
Jan 08, 2010 | Sony Walkman NWZ-S616F MP3 Player
I replaced my cab and after i switched the dashboard assembly/wiring etc the 4wd wont work !! where do the wires hook up at the fuse panel ??
DID YOU HOOK UP THE SHIFTER UNDER NEITHE THE TRUCK. IVE DONE THAT SWAP 4 TIMES THIS YEAR,AND YOU SHOULD ONLY HAVE PULLED HARNES AND COMPTER OUT OF RIGHT HAND SIDE, THE DASH CONNECTOR ON LEFT SID ENG BAY, AND YOUR SHIFTER HARNES ON THE UNDERSIDE OF THE CAB
Oct 30, 2009 | 1990 Chevrolet K1500
Have a linksy t-mobile router wrtu5g-tm and a linsky wrt54g2v1 how do hook these up for a wireless compter
First if this is a new router or not more than a year, better contact your router manufacturer and have them configure it for you.
Sep 09, 2009 | Computers & Internet
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Wont hook up to my compter
contol panel then add hardware then auto detect or installation disk
Apr 05, 2009 | Toys
Im trying to get the software for linksys to hook two compters togeter
I agree with acqwerty, you don't need a router if all you want is connect two pc's, but if you already have a linksys router, just go on www.linksys.com and download the free software that will detect and setup your router.
I hope this helps.
Good Luck.
Aug 22, 2008 | Sony VAIO PCV-V200G PC Desktop
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
