Question about Video Game Consoles & Games
Problems with my ps3
I just bought a 60 gb ps3 and when it is powered on there is no menu. It will play ps3 games but not movies nor any of my ps2 games. All I get is a black screen. Does anyone know what this is or how to fix it?
  • 83 Answers
You problably got a defective system (my friend got one he had to return it) there are a lot of people who got this it was an early version
Posted on Apr 02, 2008
SOURCE:
I have a 60 gig bought from hong kong-it plays ps2 but only region 1 ps3?Is that right,should it not play all regions?Cheers
mntool
This is correct, the PS3 will only play games and movies from its home region. Note I have some anime that is multi region disks that will not play in my PS3.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 15, 2010 | Sony PlayStation® 3 (60 GB) Console
My PS3 plays blue ray movies,dvds,ps2 and ps 1 and no ps3 games
hold the power button down when it is red till you hear the quick beeps then select the file restore this is a diagnostics menu..remember you have to hold the power button down till you see a menu that youve probably never seen
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
Replaced laser on my 60 gig ps3 because it wouldn't recognize any type of disc. Now it will play ps2bgames and cds, but will not play ps3 games or blue ray movies. What can be wrong since it is all one...
you asked for a ps2 laser.(not sure)
specify a'' check'' on your ps3 at any local futur shop
they WILL find a problem and if you payed you CHECK you get a bit more info and there mistake
Nov 01, 2009 | Sony PlayStation® 3 (60 GB) Console
How do i get ps2 games to play on my ps3
The only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can't, and there's not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won't help you out much here.
Aug 18, 2009 | Sony PlayStation® 3 (80GB) Console
Can a ps2 play ps3 games
Some models can, the 60 GB model can play all PS2 games, the 80 GB can play pretty much all PS2 games, the lower end ones (I think the 20 and 40 GB can not play PS2 games). There is a rumor however that ALL PS3's will soon be able to play PS2 games with a software update.. that will not be available until a few months into the future, if ever.
Jul 01, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 14, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 will not play any games
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
How to play ps2 game on the ps3
Playing a PS2 game on a PS3 depends on what model your PS3 is. The 40 GB does not play PS2 games, the 60 GB definatly does ,and i dont think the 80GB does
Mar 28, 2009 | Sony PlayStation® 3 (60 GB) Console
My 60 GB PS3 wont run PS2 games
Actually only 60GB PS3s supports PS2 games. But It requires particular firmware. In first instance try updating your system, then dissable the disc autoload function, insert PS2 game, and look at the game section if your soft will recognise it. If yes just try to play
Good luck
Aug 07, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Just purchased a TTX Tech wireless PS3 controller that comes with a USB key fob that connects to one of the front USB ports of my PS3 console. I have successfully synced it to my PS3 only issue I'm having is how drastically different the configuration is from the usual sixaxis controllers. I noticed between the 2 controllers there are 2 clear differences amongst them. 1 being the trigger buttons are not the same and that the circular circumference for the analog sticks are alittle bit different in size. Basically comparing the size of a 25cent coin to a 5cent coin. I'm assuming because of the analog having less of a left to right and or a up and down travelling distance due to the difference of having a smaller analog circle that it could very well change the sensitivity aspects in the game of choice (COD Black ops 2) but I mean the difference between the two controllers is beyond noticeable I've experimented with lowering the sensitivity level from what was set when using the sixaxis controller compared to when using the TTX Tech controller. For example using the sixaxis I'm set to 13 for my sensitivity but when switching to the TTX Tech to become even close to having the same feel and view while using it in comparison to the sixaxis i have had to lower my sensitivity level to an 11 or a 10 instead of the 13 and yet it still is quite noticeably different from my sixaxis controller. Also I've found that the right analog for the TTX Tech is extremely sensitive gently applying upward downward and also side to side pressure on the analog causes a significantly noticeable jump or jolt that seems to never differ in speed regardless as to what has been set for the sensitivity level in game settings. In a nut shell basically I'm asking if anyone else has noticed these things I'm experiencing and if there may be a configuration manual or program that could some how configure the TTX Tech controller to act more as if it were a sixaxis controller in the aspects of the analog sensitivities and responding timing. Yes of course a new controller with a different shape and or feel will make for a "getting used to it" experience which does generally occur after a time period of using said controller more and more often. I am more or less meaning whether or not the smoothness and or the rythem you would have with one controller be more similar with one another. If anyone is a gamer and has gone from using a normal typical original PS3 controller and unfortunately having it be no longer able to be used to play games and switching to the TTX Tech controller immediately afterwards I'm sure will know exactly what I am trying to explain. Appreciate any insight and or knowledge towards my inquiry. Thank you kindly for the assistance and of course take it easy or take it any way you can get it :)
Oct 19, 2019 | The Video Game Consoles & Games
Video Game Consoles & Games Logo
52 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
