Question about Hitachi CP-X960 Multimedia Projector
Hitachi CP-X960 Shutting Down
Hello. I have just replaced the bulb and reset the lamp timer. The projector starts up fine and then after about 5 minutes, the lamp turns off and the Power and Lamp indicator lights turn red. I have double-checked the lamp timer and it is at 0. Is there anything else I should be checking before sending it out for service?
Many Thanks,
Jason
Where can you find one?
Posted on Sep 12, 2008
  • 563 Answers
Hi Jason
This is normally a faulty Ballast ( lamp's powersupply )
It will need replacement unfortunatelly
Posted on Apr 02, 2008
How do I reset the lamp timer on a Hitachi CP-X960 projector?
From a previous question on this site:
After switching on, on the main unit press reset button and left button at same time. After a few seconds text at the very bottom of the display will show something like LAMP (1751). then release and select the same two buttons again, and then again (I think) and the LAMP (0) should appear and it is reset. if this sounds a little vague its because this is what I remember doing as I was trying different things out on my cp-x960. Original post: http://www.fixya.com/support/t599695-please_tell_me_reset_lamp_timer_hitachi
Mar 03, 2011 | Hitachi CP-X960 Multimedia Projector
To replace a bulb in the Hitachi CP-S235 LCD Projector, do I just unscrew the two screws under the plate underneath the machine? Are there any precautions I should take, like not handling the bulb? I have...
Yes to replace the lamp you need to remove the 2 screws. You can touch the lamp but I try not to. After the lamp is in you need to reset the hr timer for the lamp. to do this you need to look in manual on page 34.
If you do not have the manual you can get it here at link below.
http://www.aboutprojectors.com/pdf/hitachi-cp-s235-manual.pdf
Good luck
Oct 05, 2009 | Hitachi CP-S235 Multimedia Projector
Can't reset lamp timer
Turn on the projector, and reset the lamp timer.
(1) While the projector running, press the MENU button to open the menu.
(2) Choose the “OPTION” on the menu using the / button, then press the
button or ENTER button.
(3) Choose the “LAMP TIME” using the / button, then press and hold the
RESET button for 3 seconds.
(4) Choose the “RESET” using the button.
memo When the lamp has been replaced after
Dec 11, 2008 | Hitachi CP-X1200 Multimedia Projector
Please tell me how to reset lamp timer on Hitachi CP-x960?
May 15, 2008 | Office Equipment & Supplies
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Mar 23, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Mar 23, 2008 | Office Equipment & Supplies
Hitachi CP-L850W lamp reset (No Remote)
easy on botem vent unscrew it then u see screw in ther holding balest of the bulb unscrew it litte pull up action on its arm as u will see lift it all out to get new in then reset timer ok
Feb 03, 2008 | Hitachi CP-L850W Multimedia Projector
Hitachi CPS860 LCD Projector
Turn On. Press RESET switch for 3 or more seconds until a lamp and 2000 message appears in the middle of the bottom of the screen. Press RESET again and this message will expand to include cant remember then press arrows left arrow and the 2000 will reset to 0. If the first press does not immediately provide a message press it for longer and expect to see message on release. As mentioned you have to be quick otherwise the menu dissapears. If this happens just do it again until you get it completed.
Thanks to the previous reply.
This works it has just been done on a CPX960 without bulb replacement. SO
Dont replace the fuckin thing till it needs to be replaced.
Jan 18, 2008 | Hitachi CP860960LAMP Projector Lamp for...
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Hitachi CP-X960 Multimedia Projector Logo
425 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
