Question about iLO V27DMBX Television
Junk tv the ilo 32inch the red light stays on and u can here something when u turn it on but the screen wont come on and the light wont turn green
  • dsmryder Sep 06, 2008
    My mom has the same problem on her ILO-32HD, sound no video.
My ilo 27" tv did the same thing (red light on front but would not turn on) and after much frustration looking around on the net I finaly cracked it open. After removing enough screws to remove the back the first thing I saw was the main power board. This board has quite a few capacitors on it and I found 4 of these that had bulging tops. 3 were 1000uf/16volt and 1 was 470uf/16volt. I disconnected all wire connectors from this board and replaced them with parts from radio shack PN 272-1032 and 272-1030. The voltage rating of these are different but ok if larger than the original part. It fired right up when I put it all put back together
Posted on Apr 04, 2008
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Tv wont turn on
hmmm...ok...turn it off for around 20 minutes, to allow all energy to discharge. Then try it once again.
second...check to see that the power from wall is still good(always helps to check that)
Feb 24, 2008 | iLO 2600 Television
My toshiba 32inch tv wont turn on
A lot here would depend on the model number as there are a lot of different ones with different issues.
Got a model number?
Mar 28, 2012 | Televison & Video
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
Tv wont turn on
well first of all if anything happens when you push the button then the button works! I think you should leave this one to a professional technician. There is a circuit problem that will require advanced knowledge.
Jan 04, 2010 | Televison & Video
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Tv wont turn on
Is it plasma , or LCD?
Feb 16, 2008 | iLO 2600 Television
ILO 32inch TV
ILO 32" lcd hdmi tech support Eastern Time
8:30 am - 9:00 pm (monday through friday)
9:00 am - 5:00 pm (saturday)
1-800-428-1105
my 8 month old tv doesnt even turn blue. just blinking red light where on/off light display appears. very discouraged cause wallmart will not help. trying techsupport. i found this number from my purchase paperwork. hope it is helpfull to you.
Dec 10, 2007 | iLO 3200 32 in. LCD Television
iLO V27DMBX Television Logo
209 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
