F-30 code on Whirlpool - Duet 4.0 Cu. Washer washer not filling
    President:
  • Washing Mach... Master
  • 2,651 Answers
Heres video of someone experiencing a f30 on their duet. to remove the top panel there are 3 screws alon the back lip to remove and the panel will slide back and lift off, apears that the dispensor motor is somehow bound it self up
http://www.youtube.com/watch?v=0Iu7lM9bd7c
Posted on Apr 02, 2008
Yeah this problem was real easy to fix.  All you have to do is pop the top and "unjam" the arm on the soap dispenser.  It seems to get hung up on a plastic stop that it jumps onto.  5 minutes tops.
Posted on Sep 13, 2008
How are the Whirlpool Duet washer & dryers serviced? From the front or the back
you have to pull it out,this code means you're having prblems with the washer filling,most likely it will be the water valve but i would shut the water off,take the lines off of the washer,stick them into the washer or a bucket and turn the water on,if the water comes out then you know it's the washer and you need to change out the water valve on the washer.
Aug 18, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
WHAT IS THE CAPACITY SIZE OF MY WHIRLPOOL DUET WASHER MODEL NUMBER GHW9100LW2?
3.8 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 05, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have the front loading duet washer. The code F
F2 indicates a long drain usually caused by blockage in the filter, remove and clean out filter.
Also Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
If the above does not correct the problem, replace the pump
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
What does code F 30 mean on my whirlpool duet steam washer WFW109700VW?
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Good luck
Sep 27, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
I have a duet f/l loader. The washer fills with water when not on
I FOUND THE PROBLEM WAS THE VALVEWHICH CONTROLS THE WATER INTAKE ON THE TOP OF THE WASHER. I PICKED UP THE REPLACE VALVE IT WAS LOCATED AT THE TOP OF THE WASHER WHERE THE WATER INTAKES ARE. THIS SOLVED MY PROBLEM.
yOUR SITE WAS VERY HELPFULL
THANKS ****
Nov 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
340 people viewed this question
Top Washing Machines Experts
