Question about AOpen MX36LE-UN (91.89Q10.101) Motherboard
No image on monitor. I added new ram 1GB and a wireless card to my computer. Everything was working well.The problem started when the power went off from my house. When I tried to turn on my PC again.. all I got was a beep and yellow light from it. The CPU fan runs yet I get nothing else. I tried using different monitors just in case it was my new monitor but I got the same result, no image. I tried switching different power cables and still no luck. Does this mean i need a new motherboard or can this be another problem? Help! I'm not a computer savvy :s. Aitana
    Genius:
  • 1,027 Answers
It may be the motherboard but I would suspect it more likely the power supply not providing proper voltage requirements.
To bad you don't have a soyo diagnostic board or pwr supply tester.
Posted on Apr 02, 2008
SOURCE:
Self having the following configuration on Home desktop PC. INTEL 1.7GHz, P4, D845GBV motheboard with AGP ATI Radeon 9000 graphics card, RAM is 2 x DIMM DDR2 266 Hz, 1 x 1GB + 1 x 512MB total 1.5GB RAM....
Power down and disconnect AC power from your PC. Remove the AGP card and DIMM again and use some "canned air" or dusting spray to get any dust off the contacts on your motherboard and your memory and AGP card. Wiping the AGP card contacts with some isopropyl alcohol (also known as IPA or "rubbing alcohol") and a clean, lint-free cloth can also help. When everything is dry, put your card and memory back in and try powering up again.
Mar 21, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Installed RAM and now monitor has no display. I
The splash screen with the LG Flatron logo is the monitor's splash screen not the PCs.
The machine is NOT booting up the splash screen is the monitor coming on.
Remove the 1Gb stick an see if the machine performs normally.
If it does then power it off, remove the power cord and CAREFULLY reinstall the new stick.
If it fails to boot you may have a defective memory module.
If the machine fails to boot with the new stick removed make sure you have the original memory seated properly and all cables securely attached
Jan 03, 2011 | EliteGroup Computers & Internet
Mouse continually skips around. I changed batteries, reset it and everything. What's wrong?
You have the tracking speed set too high.Go to 'start'-'control panel'-'printers and other hardware'-'mouse'.After opening mouse you'll see "pointer options",click and you'll see "pointer speed".Move the speed down from fast to slow until you can see it easily.The other thing is if you don't have enough RAM memory it won't be able to keep up with simple hand movements.Click "start'-right click"computer"left click"properties"and up will come what you have for a computer will be displayed.Near the bottom of the page will be RAM,to it's left is how much you have.XP you need at least 512MB(1GB is better-up to 3GB best)Vista 1GB minimum,up to 6GB with Vista x64.Adding Ram is the easiest way to speed up a sluggish machine.Please re post if you'd like to get into changing setting for best performance.
Dec 30, 2009 | Dynex Wireless Optical Laptop Mouse...
My1 gb ram didn't make any change even in games in my pc even those games which used to run at a particular speed earlier before the added ram are running just like thet speed even after adding 1gb more...
Ok, let's explain this. RAM does not necessarily make your pc faster.
Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics).
RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare.
Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't.
if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be.
Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Feb 19, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Can I put to much RAM in the motherboard for the Processor?
That additional RAM will be good for your computer so it will be much faster and don't worry everything should work fine there after adding new RAM to your computer....
Jan 13, 2009 | Intel (C733) Celeron A, 700 MHz Processor
Video Card
It is likely to be your old graphics drivers conflicting with the new card - Put the old card back in and be sure to remove them
1. Start
2. Right Click My Computer
3. Properties
4. Hardware Tab
5. Device Manager
6. Display Adapter
7. Uninstall
Turn your PC off and place the new card in then reboot
Install the new drivers after booting.
If this helped dont forget to rate me ;)
Blazamane
Jan 08, 2009 | Dell Dimension 4700 PC Desktop
Everything works, but no display
Try a different stick of RAM. Like a smaller amount. try 512MB and see what happens. if 512 works, try the 1 of the 1GB sticks so you can still have atleast have 1GB.
Jun 11, 2008 | ECS 945P-A (V3.0) Motherboard
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Apparent conflict between my wireless adapter and RAM
have you tried looking for an updated bios version for your motherboard?
Jan 05, 2008 | Computers & Internet
AOpen MX36LE-UN (91.89Q10.101) Motherboard Logo
56 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
