Question about Maytag UXT5230AD Kitchen Hood
How to Install as Ductless
Ordered a ductless range hood and was sent this model. Not sure how to install ductless. It says I need filters but that does not affect my install does it. What do I need to do.
  • Anonymous Jun 06, 2008
    Same story here, and I had to deal with that model. The installation was OK though, but I am looking for those carbon filters now, and the cheapest I have found are $ 50+ !! amazing !!! Any idea of cheaper models that could match it up ?? it's a maytag UXT5230adx .
    Thanks.
    President:
  • 1,304 Answers
It should mount sqaurely to the bottom of the cabinets over the stove/oven
you will need a 120v power supply
but it is pretty straight forward other wise
Posted on Oct 05, 2009
6ya staff
SOURCE:
Best way to install a 30 inch range hood
The pipe size on the old one was 8 inch and you are putting in a 6? There are no issues with that. IF it was the other way then the pipe was 6 and the hood was 8, there would be an issue. Ductless systems vent the vapor back into the room and there is no benefit from it other than to reduce the steam. If there is a metal filter grid from scintillated metal then it will attempt to catch the grease vapor because it is a lower temp.
Feb 05, 2018 | Kitchen Ranges
I have a Goldstar mv1610ww that is currently set up for external/ducted venting. How do I switch it to ductless/recirculated venting? What additional parts do I need? It currently has the perforated v
That information is in your installation manual that came with the oven.
If for some reason you don't still have that, then you can order it or see a video at LG's site.
The LG product support page for your model is here.
If you'll scroll down to the middle video, they show you how to install it.
That will help you when you uninstall the oven so you can swap the vent fan assembly around.
I would bet you'd also need to order a charcoal filter.
The service manuals is here, but it does not contain part numbers.
You can get LG part numbers and order parts from Encompass here or you can call them toll-free at 866-779-5835.
Dec 10, 2012 | Microwave Ovens
Can this Microwave be converted to ductless with a chgarcoal filter? If so what is the part # I need to convert to ductless? Thanks Leagh
We would need your brand and model number to be able to answer, but your installation instructions would tell.
If for some reason you don't still have yours:
You can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 16, 2011 | GE Spacemaker JVM1540 Microwave Oven
How do you work it
rwandih - Are you sure you listed the correct model number. As the RHFE series heaters a Direct Vent models, not "Ductless". Please advise, so the I can forward you the correct Owner's Manual.
Thanks
May 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
When buying a wall mounted range hood, do I need
If you are going to use the hood ductless you just need to make sure that it comes with a charcoal filter or buy one at the time. Also you need to make sure the hood can be used ductless.
May 08, 2010 | Kitchen Ranges
When buying a wall mounted range hood, do I need to buy any additional if using it as a ductless hood.
If you are going to use it as ductless then you will not need to buy anything else.
Apr 10, 2010 | Broan-NuTone Kitchen Ranges
Hello-I am being given a Jenn-Air electric range soon. My current electric stove just has the vent pipe coming up under a back element. Will I need to vent the Jenn-air to the outside? I have an...
Yes the ductless fan will work for you. I have that setup here at my house. Just make sure that you have a charcoal filter installed in the microwave where the air comes out on top. If it is already vent less the filter is probably already there.
Good Luck and Please Rate FixYa!
Mar 03, 2009 | Jenn-Air SVE47100 Slide-In Electric...
PANASONIC DUCTLESS SPLIT
Try to check the resistance of your room air and coil thermistor may be its out of range the reading of both thermistor is 8000 to 10000 ohms @ 25deg C temperature. if its higher or lower then the thermistor is out of range and need replacement. And try also to check your terminals and connector for loose.
Mar 18, 2008 | Heating & Cooling
No exhaust in ductless mode
they are indeed
you need to take off the filters
you will sede then you need to turn then 90 degrees to vent out
Mar 12, 2008 | Jenn-Air JXT5830AD Kitchen Hood
Maytag UXT5230AD Kitchen Hood Logo
367 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
