Question about Optoma EzPro 739 Multimedia Projector
We have an optoma ep739. when you turn the lamp on, a message 'fan failure' comes on. the fan is running at what appears to be a slow speed. the red temp light goes on and then the lamp turn off.
  • 563 Answers
Hi there
Try cleaning out the fan by blowing it out with a compressor. Most of the time this is only caused by dust.
If the problem stil occurs , try spraying it on the inside with a lubricant.
If the problem stil occurs you will have to replace the faulty fan.
Very cheap to have replaced.
Posted on Apr 02, 2008
Unit is shutting down after ten min
My unit never got to the point of actually shutting down due to overheating, but your problem may be related to what I experienced: A bent lamp heat shield.
My Optoma EP739 started exhibiting color-banding and strong color shift after years of great service. After trying other suggestions that didn't work, here is the FIX for my unit. I have not seen this posted anywhere else.
Problem: After 10-20 minutes of use, color-banding and then a strong shift to purple/green with almost no red. If the unit is turned off for 5-10 minutes to cool and then powered-up again the problem goes away, only to come back in another 10-20 minutes. Enabling the "High Altitude" setting in the Setup Menu helped for a while (a week or two) since it forces the main cooling fan run at high speed always, but then the problem re-appeared.
Reason: Overheating. The electronics are overheating. Like several people have suggested: First step: Open the unit up and blow-out/vacuum all of the accumulated dust. Assure BOTH fans (there is a small drum blower directly cooling the lamp and a larger regular fan that circulates air through the entire unit) are operating and clear of debris.
Once you have done that, then look for the REAL issue. With the front panel (i.e.the panel with the hole for the lens) removed and looking into the projector from the front examine the metal heat shield on the right side above the lamp. In my unit, because of years of service and heat, the aluminum lamp housing had deformed slightly, tilting this sheet metal heat shield directly INTO the air stream from the fan. This restricts the airflow enough to reduce cooling capacity. This metal shield should be high enough above the lamp to be TOUCHING the plastic case. If it is bent down and is halfway into the air stream then it restricting the exhaust airflow, causing the overheating.
Fix: Bend the heat shield back up so that it is not in the exhaust airflow. It must be ABOVE the airflow, protecting the plastic case from the heat of the lamp. This simple remedy fixed the issue for me. My projector has been running 2-3 hours a day for 10 days now with no banding issues at all. That's it. Simple fix.
Feb 01, 2013 | Optoma EP739 Multimedia Projector
Unit is shutting down due to bulb overheat
My EP739 never got to the point where it actually shutdown due to overheating, but the root-cause may be the same. First thing you must do is clean out any dust and debris that may be restricting airflow. If that doesn't help then read-on...
We have a optoma ep739 used at our local football club;but whenit gets warm it cuts out until it cools down;isthere any filters that need cleaning
take the lamp out, there is a fan directly looking to the lamp... clean it with a compressor. and after that at the menu of projector there is a place called 'High Altitude'. turn it on. And it'll be fine...
Mar 01, 2010 | Optoma EP739 Multimedia Projector
Optoma RD50 TV which shuts down on #1 fan failure
This could be a variant of, or a newer (or older) version of the "DMD fan failure" message.
Symptoms I had are, I stop hearing a fan when the message is displayed.
Then the temp LED keeps flashing RED until I either try to turn the TV on again,
Or turn MAIN power off/on again. BUT it repeats when I try to turn the TV on.
The picture appears normal until this happens ( about 15 sec.)
The solution is to FORCE a normal shutdown by hitting the TV off button
before the message appears.
You should see the power LED flashing RED/GREEN (cool down) and then RED (standby).
Apr 20, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Optima getting fan fail error what can I do?
its eather it is dusty or the fan morter is burn out.
Jan 04, 2009 | Optoma EP739 Multimedia Projector
Optoma EP739
The lamp cover has a disconnect that wont allow the unit to power on while the cover is off.
Try taking the lamp cover off and bending the little piece of metal you find underneith.
It worked for me.
Nov 01, 2008 | Optoma EP739 Multimedia Projector
Powers off and lamp never comes on (new lamp tested in other ep739)
The lamp might be burn out or you do ot have the computer in the right plug and the right input slected.
Jul 23, 2008 | Optoma EP739 Multimedia Projector
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
238 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
