Question about Philips 60PP9352 60" Rear Projection Television
No picture I have sound but no picture. just had a new dvr cable box installed by comcast. the tv worked fine while the tech was here. I went out of town for a few days. when i came home the tv picture would not come on.
I unhooked the coaxial cable from the dvr and attached it directly to the tv, the picture was fine. re-attached the cable to dvr and secured it with a rench, it worked. the tech only finger tightened the cable and when I pushed the tv back into place the wire spun too loose
Posted on Apr 02, 2008
  • 934 Answers
It's likely the Ssb is out, Philips p/n# 319801634710 which on a difficult scale of 1-10 is about a 6 or 7 for repairs. That is a DPTV310 chassis and somewhat tight quarters inside. It's not so bad taking the strappings loose to get at the board but a tight area to work through getting the standup board unplugged from the signal board. One noteable caution: unplug the set for at least 10 minutes before opening the back VERY STATIC SENSITIVE..
Bill
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
RCA l42wd22yx5 green screen when on HDMI... Still get sound
We had the same problem. What we did was unplug our DVR box from Comcast to reset it and plugged it back in and the picture came back.
Dec 05, 2009 | Televison & Video
TV has no picture but has sound
Did you say you went in to DVR set-up and checked the component out audio option? I have had similiar problems with motorola dvr boxes and once I was able to enable audio output option the dvr digital output was fine. Find the manual for the model dvd and this may cure.
Jan 31, 2009 | Denon Audio Players & Recorders
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
No Picture
Do your on screen display work when you push menu?
Jun 29, 2008 | Philips 51PW9363 51" Rear Projection...
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Philips 60PP9352 60" Rear Projection Television Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
