Question about Cnet Pro200 Network Adapter
No Connection My daughter recently upgraded a pc from Windows 95 to XP. It has a CNet Pro 200 net adapter already. When he connected to DSL it gives him the message " a network cable is unplugged." The cables are good. Does this adapter work with XP?
MUCHAS GRACIAS POR LA PAGINA......EN VERDAD ALLI SE PUEDE DESCARGAR AL INSTALADOR......ME SIRVIó DE MUCHO....GRACIAS MILLLLLLLLLLL
Posted on May 11, 2008
  • 31 Answers
Cnet's website does not show this NIC as having any XP drivers for it so I would say no it is not compatible.
http://www.cnetusa.com/product/specs/nics_pro200.htm
Posted on Apr 02, 2008
Intermittent DSL connection. Frequent need to reboot modem.
the modem is already old and obselete try to upgrade the modem. even though the lights on your modem works. try to call ATT because they can run a line test so they can determine if the connection is good or not
May 22, 2010 | Efficient Networks SpeedStream 5360...
Cant get net connection
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/Dell-Vostro-200-LAN-Driver.shtml
May 31, 2009 | Dell Vostro 200 PC Desktop
No Networks Recognized when I upgraded to XP Pro
Are you using a wired or wireless connection?
Check the Device Manager to see if there are any missing drivers or yellow exclamation points.
Report back.
Mar 10, 2009 | Acer Aspire™ T180 PC Desktop
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
DSL-210 for Windows XP
upgrade your windows xp, drivers are not required to use the router on your computer if you are using the windows xp. or you should have a look at your lan drivers first  or if you are trying to connect your router using the usb cable, please try to update your usb drivers.
for drivers download  http://ftp.dlink.ru/pub/ADSL/DSL-210/Drivers/DSL_210_Driver.zip
Jan 24, 2009 | D-Link DSL 200 (DSL-200) Modem
Compaq presario sr2020nx ethernet adapter issue
Since youre setting up a DSL connection choose Set up broadband connection > PPPoE. You will need the username and password you were given to this account (contact customer service at your ISP for this info). Enter the info and have it remember the password. Click connect. Once Vista finds the connection, it will ask you to choose a network type (Home, Work, or Public). Select the type and enjoy. If the connection fails, recheck your username and password entries.
Jan 18, 2009 | HP Compaq Presario SR2150NX PC Desktop
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Ethernet driver
dear brian,
to get you an overview on which components you have, although not installed or recognized by win xp pro, download pcwizard2008, install and run the hardware detection program, it'll give you a lots of details about your computer, you can even save the data to a pdf-file.
networking components on your laptop may be:
- the 1394 adaptor
- the( to be found) ethernet card
- and if it is onboard or u plug it in via USB 2.0 port: the WLAN-adaptor
look for the (onboard?) realtek ethernet
card(rj-45 plug, similiar to dsl-cable)
using pcwizard, find out about the model and download suitable driver rom the net for winXP.
install and then try setting up a network/internet connection
(be wise enough to use the right cable:
for hooking up your lap to an internet dsl-router use dsl cable, to establish PC to laptop connecton you will need DSL cable plus crossover adaptor !)
i recommend to use cable connections, they're
older, more reliable and for safety reasons, better than wirelessLAN!
if you have used the 1394-network adaptor before, you are better than me, I dunno anything about it.
WLAN is an option when using laptop not at home- but don't clearly understand if the toshiba model u use already has WLAN-onboard device or u do use an external, USB 2.0 device to connect to the net...?
please give more detail about that- and do tell which toshiba laptop u use as this is helpful for me to find u a proper driver, if still needed.
C U here on fixya?!
Oct 21, 2008 | Computers & Internet
Intel Pro Wireless 3945abg not connecting to higher speed DSL
router wireless limitations. if it was N type router it would go faster.
Oct 14, 2008 | Intel PRO/Wireless 3945ABG Network...
Cnet Pro200 Network Adapter Logo
160 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
Marcin
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
