Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
I have lines like vertical hold is off but can't find ajustment
I cannot find the adjustment for vertical hold
  • 934 Answers
Isn't one in the customer menu - only in the service menu..
Bill
Posted on Apr 02, 2008
My seiki tv has vertical lines running in it and keep rolling upward ... any suggestions?
indicates the vertical hold system needs adjusting or there is a problem with vertical hold board
there may be a button adjustment on the set
too far one way it goes up , too far the other and it goes down
Oct 18, 2017 | Seiki Televison & Video
I have 2 lg repair the same trouble vertical horizontal rolling
Vertical or frame rolling indicates adjustment of the frame hold is required or perhaps there is a synchronisation fault.
Breaking of the picture in the horizontal plane is caused by the line hold requiring adjustment though the symptom can be connected with interior or exterior signal problems or perhaps a power supply fault, especially where both the line and frame are affected together.
It is probably a task for an engineer or at least someone with access to the servicing instructions.
Feb 25, 2015 | LG Televison & Video
Picture is like dull. i ajust the focus in the flyback then comes like fine vertical lines
The trouble is not the focus of the flyback transformer, the one you adjust is the screen try to return the original position. try to check the crt socket it is connected to the picture tube if you see something in the pin that is color green it is corroded try to replace it with the same type of crt socket.
May 20, 2011 | Televison & Video
Vertical line at edge of AV1 channel
hi! he might have adjusted the vertical hold and height including the linearity. normally on the board you would see a trimmer resistor with a label v-hold this is to stop the rolling, v- height for the size of the picture. and linearity for the evenness of the picture from top to bottom.
Aug 28, 2009 | Televison & Video
Thank you to "TheScreenGuy". He replied with an answer that says the vertical sync is automatic and that I need to replace the SSB. Thanks!!!
Mar 23, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Headlights needs ajusting
on each headlamp assembly, there will be either one or two plastic nuts that you can turn.
If you only have one nut on each, that will adjust the vertical aim of the headlights.
If you have two nuts on each, one will adjust the vertical and the other will adjust the horizontal.
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
Mar 14, 2009 | 2004 Nissan XTerra
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
Visual
The same is true for rear projection. There may be an adjustment for vertical hold in a hole in the back of the cabinet.
Oct 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Wanlida LTD-1510
sounds like filter ac problems dont ajust anthing check for cold solder connections
Sep 11, 2007 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
