Whenever i try to copy it says that paper is jam
    Sergeant:
  • 247 Answers
I assume this is a printer or copy machine and not a PC.
However, sometimes its not easy to locate the paper jam. But, you need to find and clear the jam. Take out the paper tray(s) and look carefully. You may have to remove the toner cartridge or even the drum.
If there is no jam, one of the sensors may be clogged or defective.
Hope this helps :)
Posted on Apr 02, 2008
SOURCE:
Have an HP 1040 Fax machine, whenever I try to copy, I scans fine, but then it brings up message that says remove jammed paper and press cancel even though there is no paper in it and when I do this, it...
The paper could be as small as a pin head stuck at one of the rollers. get a can of air and manually move the rollers while blowing them and blow all openings around the paper feed area.
Oct 23, 2012 | Office Equipment & Supplies
I have a Ricoh Aficio 2045 and whenever i try to copy double sided the paper jams in the copier but is fine when copying single sided. It always Jams at Point C in the photocopier?? Can anyone help me??
This jam problems are always very difficult to solve without seeing the machine!
Because i need to see the jam location or take a report to see where the paper jams.
you say that it is on the Point C, but that just helps a little.
I can tell you that you have a problem in the duplex door (but you already know that). It could be several things like; transport rollers, gates, solenoids... well, the best help i can give you is to advise you to call your technical support.
See you!
Apr 30, 2011 | Ricoh Aficio 450 Copier
Paper jam
im assuming you are using regular copy paper, is so fan the paper out before you put it in the printer and also check to see if the roller inside the printer are clean. they pull the paper threw the machine.
Jun 28, 2009 | Brother MFC-3240C All-In-One InkJet...
Cant see paper jam but when I try to copy I get paper jam message
The paper sensor flag is most probably jammed. This will require you to take it to yor closest repair centre. Ths uually happens when you had a paper jem and pilled the paper out in the wrong direction.
May 20, 2009 | Office Equipment & Supplies
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
I have a HP OfficeJet 6210 all-in-one printer...whenever I make a copy by inserting sheet into feeder a long black line appears on the page. It is as if there were a long black line on the original. This...
I have the same printer and have the same problem. I found out though that sometimes this works: when you make a copy, select the best quality option. Again this only works sometimes.
Dec 26, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Computers & Internet Logo
43 people viewed this question
Ekse
Alun Cox
