Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Went from Analog thermosat to a Honeywell 5000 series Digital Thermostat. Worked fine all winter. Now, when I put it on Cool it pushes out Heat. This is a Trane Heatpump.
  • 56 Answers
Look to see if you have it wired correctly with the o terminal be used and then check to see if you have a jumper wire between the Y and W terminal on the Base of the tstat where you hooked all the wires up.
Posted on Feb 14, 2009
6ya staff
SOURCE:
I have a Honeywell Chronotherm IV plus with a Carrier 25HBA heat pump. Installed last winter and worked great. This spring set to cool and will not cool.
Be sure it is wired for heat pump rather than conventional and also tstat has been told it is operating a heat pump in the settings menu.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 12, 2018 | Carrier Heating & Cooling
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Honeywell RTH2310b thermostate - my thermostat worked just fine through the winter with the heat but now it won't kick on the central air. I have tried switching the yellow(cool) and the white(heat) to...
You can check your float switch, power to both the air handler and outside condensing unit and ensure power is present, also check control voltage from transformer ensure 24Volts on secondary side. If you are not comfortable around electricity though I recommend you call your A/C Contractor for safety reasons.
Further information would be needed to further diagnose your problem.
Jul 05, 2011 | Honeywell Heating & Cooling
Replacing analog thermostat with digital
alot of those gas fireplaces work on what is called powerpyle or 750 mv if your old thermastat has a ts in model then you would need tstat that works with millivolt systems
May 04, 2009 | Honeywell Electronic Programmable...
Cool air not working with honeywell Model # RTH230B
Do you have a heat pump? If so, not compatible. What i did was move the jumper on the thermostat (RH RE). This is on the inside of the thermostat - NOT the red jumper!!! and got the AC working (the heat had already worked during the winter, problem only became apparent when I needed to use AC). I may have to change the jumper again when the season changes...not sure yet.
Apr 26, 2009 | Honeywell Programmable Thermostat Heater
How to work my thermostat
Fan switch should be on auto in the heating mode and on in cooling. Contact the manufactuer on line for a new manual for this thermostat.
Ray
Dec 14, 2008 | Honeywell Electronic Programmable...
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
159 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
