Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Not Supported Mode
I have a Samsung HLN5065w, While watching the set the screen went black, then the sound went out. The tv would not shut off. I unplugged it and when it finally came back on all that was on the screen was verticle lines, the sound had returned. After resetting the tv a few times, the picture and sound had returned, but ALL digital inputs are now displaying "not supported mode". Picture and sound are only on the analog inputs "i.e. video 1-3 and antenna. ALL other inputs display not supported.
No inputs were changed prior to problem. However, colorwheel was replaced 2 weeks ago.
  • 2 more comments
  • garb2jr Apr 02, 2008
    I looked up this part, and it looks like it's just the digital inputs. However the component inputs are not working either.
    yes the composite inputs are working, however the components do not. Basically, the HD inputs. This problem is intermitten, as all inputs returned to normal last night, then stopped working today.
  • garb2jr Apr 04, 2008
    Now the inputs are working intermittently, but the color has gone all wacky. On antenna and composite inputs all is green, on component and digital inputs are purple. What the heck is going on.
  • chrisannie1 May 14, 2008
    I have a similar problem, however both by Components 2 and 3 state NOT SUPPORTED MODE, so I can only use COmponent 1. The tv works fine when in Component 1, and I can watch DVD's only when plugged in Component 1. Do I really need to have a technician come out for $100??? Does anyone know a fix for this?
  • 934 Answers
Sound as if the digital board has failed, Samsung p/n# Bp94-00385a
Bill
Posted on Apr 02, 2008
  • William Rayburn
    William Rayburn Apr 02, 2008
    I thought you said you had video, "...on the analog inputs". No matter - you might be looking at replacing both.. The analog board is p/n# Bp94-00434a
    Bill
  • William Rayburn
    Failed digital board - one or more smt caps are probably failing and what you'll notice is temp sensitive. Better to just replace the digital board..
    Bill
SAMSUNG TV- model: HLN4365WX/XAA: Component 2 mode not supported
One thing to try is whatever (a box?) connected to that input--remove power from for a short while and then plug back to see if that will reboot the unit connected there.
May 23, 2012 | Televison & Video
Comcastt HD Box indicates "Component 3 - Not supported mode"
Try HDMI if the TV has the inputs or swap the component cable.
Jul 02, 2009 | Samsung HLN5065W 50" Rear Projection...
Our tv made a loud high pitched noise for a few weeks and then the color went green to then shutting off. Now, when we try to turn on the tv, the light blinks and then it just shuts off and keeps repeating...
Hi, Symptom shows high pitch sound is of color wheel that is not spinning any more so TV stay in protection mode and does not power up. TV requires color wheel replacement.
Jun 15, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W shuts down in a minute
2 tings, ,lamp fan motor stops or temp. sensor located on optical block activated
Mar 01, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HL-R4667W black screen, display says "Lamp"
it means you need to replace a lamp when it says that
Jan 30, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung hl61750a - unable to display video service over hdmi
I was using an hdmi cable purchased online. A friend told me that it might be the 'cheap' hdmi cable. I tried a set of Monster hdmi cables and problem solved. So all hdmi cables are not the same.
Jan 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture on Samsung HLN5065W
sounds like the color wheel has gone bad..the part is not very expensive but it takes some work to replace it
Nov 29, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
346 people viewed this question
Henry  Thomas
Henry Thomas
