Question about HP Photosmart 7450 InkJet Printer
Too Much Paper
When I print anything on regular paper, the printer pulls in 3 pages one after another and spits them out before printing my document, and after it's through printing it continues to pull in paper until it either runs out or jams. Any suggestions?
    Problem Solver:
  • 10 Answers
2 possible solutions.
1 The paper itself. Check that the paper tray is not overfull. this can cause multiple sheets to feed through. Also make sure that you use good quality paper suitable for the particular type of printer. Always keep the paper dry Damp (not wet) paper will also cause the sort of problem you describe. another good reason for not keeping to much paper in the paper tray. Paper will keep better in the packet than in the tray. Always store the paper in the packet in a warm dry place. I keep mine near a radiator and away from the Air con.
2. The printer driver. Download the latest driver for your printer from the manufacturer and update the printer driver, via the control panel/printers. If you don't know how to do this you can simply uninstall the printer and then install it again using the new printer driver.
Good Luck
Carrieone
Posted on Jun 13, 2008
How do I get my HP OfficeJet Pro 8725 printer to spit out the printed paper without force and an extra sheet?
Have the memory inside the printer tested. Add as much printer memory as you can to the printer to speed it up.
Mar 16, 2017 | HP OfficeJet Office Equipment & Supplies
HP photosmart c8100 all in one printer 10x15 photo paper spits out when ever you try to print a photo from printer .new printer thanks Ray
do the normal copies of microsoft worf comes out properly without any spitting.then its the setting problem in your printer .you can change the settings through printer properties --just adjust the photo settings in your printer and it will print the photos.
but if the word document are also having the same problem its the printer problem get the replacement as the printer is new.
feel free for further queries.
thanks.
Sep 20, 2008 | HP Office Equipment & Supplies
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
Hp 2280 wont print says no paper or ink
Start by uninstalling the printer software... then re-install the newest software from the HP website. Always works for me...
Jan 25, 2012 | HP DeskJet F380 All-In-One Printer
Only one half of the picture prints.
Hi friend,
This is depend on the page layout or preference the pages,firstly sure that you have the correct page layout in your program and set the printer preferences to "Print as in document" or Fit to page whatever the template requires.
 this is really helpful to you.
Thanks,
Dec 23, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Printer
What printer and software are you using?
Does it do this for anything you print. Example a word document.
Oct 10, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
