Question about Pioneer Audio Players & Recorders
I have a SX-950 Pioneer Receiver 31 years old. The power relay protection on the power on switch will sometimss click on and sometimes not. When it does click on the receiver will play fine for a minute or so then click off again. I cannot find a replacement for the part no.ASR-019-0 type 4U 24VDC power relay. Do you have any suggestions or maybe even a solution. I have thoroughly cleaned the inside and rewired the speakers. Thanks Randy in Rome Ga.
  • Pioneer Master
  • 4,048 Answers
As the part may not be made anymore you could buy a 12-15/16 volt switch with the same fitting and put a resister in the power side to the switch. as the switch is only these volts, I have had to do this on a few items myself, you can buy the switches that can have the resistor slot on them but they are a lot more expensive and you have to solder the resister in place on the switch. but if you remove the old switch and on the side were the power for the relay is on one side put a resistor depending on 12v etc saying 12 volt as it would be 50% resistance to lower 24 to 12 volts. solder that to the board leaving room and bend the pin on switch on that side were it would be fitted and solder the resistor to that after the switch is fitted, there should be room to do this and should be fine for the switches like.
Posted on Jun 22, 2017
    Top Expert:
  • Pioneer Master
  • 30,517 Answers
Nothing wrong with the relay.
Try reflowing the solder under the heavy components and regulators.
2 Suggested Answers
6ya staff
SOURCE:
ABRsvcs
  • 4234 Answers
SOURCE: SX-950 Stereo Pioneer Receiver
The relay is a protection device for the speakers. It will shut off the speakers when problems are detected internally. I would suspect that some of the capacitors in the front end are in need of replacing. This is a common item for units this old. I have restored a number of these for customers over the years with much success. Figure about $15-$20 in parts for this repair plus the local labor rate. This unit is definately worth a refurb. What happens is that there is dsome DC voltage being leaked into the final amplification stage. This triggers the protection circuit to shut off the speakers. DC voltage on a speaker will heat up the coil and eventually destroy the speaker.
Dan
Posted on Apr 02, 2008
Pioneer sx-850 goes into protection after several minutes of use. It seems to be after warm up or when room temperature is too high. Summer temps.
Did you check whether the protection assy is working properly? The protection circuit is checking the current of the power transistors as far as I remeber. So there are several possibilities for that fault.
You should grab the service manual or at least schematic (http://elektrotanya.com/pioneer_sx-850_sch.pdf/download.html) and then go step-by-step. I recommend to start up with the protection assy itself. If this works properly go for the power amp. It is also not unlikely that the power supply is the cause of the problem.
Good luck.
Dec 05, 2013 | Pioneer Vintage Sx 850 Stereo Receiver...
Power switch on my Pioneer SX-950 receiver is hard to move.
Buy some electronic contact cleaner in a spray can, attach straw, "unplug receiver" and spray the power button, you may have to remove to be more effective.
Apr 15, 2012 | Pioneer Vintage Sx-980 Sx 980 Receiver
How do i hook up an antenna to the pioneer sx-950
There are two antenna sources on the Pioneer SX-950.
Both of these outputs are located on the rear panel of the receiver. The AM is a permanent mount. The FM is standard RF/Coax which will run to your antenna.
Antenna Inputs: FM 75 ohm, FM 300 ohm
Am Ferrite Bar Antenna
Hope this helps,
TechGuy21
A
s
Jul 04, 2011 | Audio Players & Recorders
Tone switch causing loud pop in speakers tripping protectiveRelay
The tone control on this one sounds like it is an active one and either using the low or high pass filter you would be boosting the higher or lower frequencies. Boosting the lower frequecies will be harder on the amplifier, in which case if you would like to use then you may need to connect speakers with a lower impedance or higher sensitivity.
Dec 12, 2009 | Sansui RZ-5300AV Receiver
SX-205. Left channel doesn't work.Internal problem. Should I change any semiconductors / transistors,diods or other/? How to find out,which semiconductor is bad? Please,help me.
Check the final output relays first. They are mechanical and have been known to fail after so many cycles. The click you hear about 3 seconds after you push the power button are those relays.
Apr 04, 2009 | Pioneer SX-205 Receiver
I have a Pioneer SX-850 Stereo from the 70's that just stopped working. When powered up all the lights, knobs, buttons, switches, etc. work, but no sound comes out. I also do not hear that distinctive...
Hi and welcome to FixYa,
That distinct click is the relay activating. It is the built-in protection common to designs of this period. The only time the relay will not activate is when the protection circuitry has detected a fault in the amplifier/output stake. This would call for replacement of the defective components most likely a transistor complimentary pair or in some instances a large IC power pack.
Good luck and Thank you for using FixYa.
Dec 07, 2008 | Pioneer Audio Players & Recorders
Pioneer SX-950
use a cable tester for the wires that are connecting to the unit and you'll find the faulty wire that is bad.....good luck
Nov 03, 2008 | Pioneer AVIC-S1 GPS Receiver
Pioneer SX-950
Speaker Relay Output Switch was a common problem with most SX models of the 70's. It's the switch you hear click on after about 4 seconds of power switch being turned on. It's still avail. thru Pioneer parts for around $45.
Jul 28, 2008 | Pioneer AVIC-S1 GPS Receiver
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
Dan
Apr 02, 2008 | Audio Players & Recorders
610 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
