Question about Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125 how to thread bobbin - Brother LS-2125 Mechanical Sewing Machine
  • kjfchill Mar 04, 2010
    how to insert bobbin
All manuals for a brother sewing machine are downloadable at www.brother-usa.com
Posted on Jun 12, 2008
I need to learn how to thread this brother sewing machine
Posted on Aug 02, 2009
  • Brother Master
  • 5,568 Answers
The entire user's guide is available here at Fixya:
http://www.fixya.com/support/p131539-brother_ls_2125_mechanical_sewing
Posted on Apr 29, 2008
  • 7 Answers
SOURCE: bobbin case is disassembled. how do I put it back together?
It should be in your manual.... but if you don't have one, I'm gonna try this out. I don't know the official names, so bear with me.
There should be two plastic arm-lookin things that are turnable. Make sure these are turned outwards.
You should have three silver pieces. The one you need first is a half-moon looking thing with a knob comin out of the middle. (it also has some holes in it)
If you turn the big knob on the right hand side, there should be a moving piece on the inside of the bobbin case.
The half moon needs to fit in with that piece. Don't force anything cause we don't want the machine to break. >< The knob thing needs to be facing the outside, otherwise it's not gonna go in at all.
Once you get the half-moon thing in there, you have two more left. There's a big circle. WOO! CIRCLES! ANYWHO, The big silvery circle.. it has a knotch in it, and a little pokey-outie thing comin' out of it.
It needs to be positioned so that the knotch (on the inside of the circle) is up and the pokey-outie piece (on the outer side of the circle) is on the bottom. On your machine, there should be a place where the pokey-outie piece would fit perfectly into a little hole-type-thing. Put it in. :O
Now it's time to move those little black plastic arms towards the center. On your circle, there should be little grooves that they fit right on top of. ^_^
The only silver piece left should be the actual bobbin case deal. This should be a smaller circle with a movable arm and a silver thing pokin' out of it. (I told you, I'm bad at names!) Before you put this guy in, we need to have your plastic bobbin threaded. (I'm assuming this has already been done, correct me if I'm wrong.... they also have pre-threaded bobbins for sale, but hey, whatever works.)
Your bobbin needs to fit inside this last piece. (my first bobbin didn't, and I freaked out and ran to my dad... LOL) You need to make sure there is a trail of thread coming out of your bobbin that's about two to three inches long. Place your bobbin in the silver guy and there /should/ be a little niche where you can play with the thread and pull it through the silver guy's parts. (Your thread may break, don't worry, just try again)
When you move the thread around, it should come out where the little arm that sticks out is. Keep the 2-3 inch trail goin' on, you'll need it. Remember that first half-moon silver guy? Well, we're gonna stick our little assembly onto his pokey-outie piece.
The silver arm-thing on our assembly needs to go into the knotch that's in our circle, and push in so it clicks. (Sometimes mine clicks twice...) Make sure you have that trail of thread, and go ahead and flip the white plastic up, because you're DONE assembling it.
I'm going to assume you have your top thread in already (again, correct me if I'm wrong..) make sure that your top thread is through the hole in the needle, otherwise we're thoroughly screwed. Pull that thread until you have another 2-3 inch tail, and twist the big white knob on the right side of your machine (same one as before...) TOWARDS you. KEEP HOLDING your top thread, otherwise it'll disappear into the abyss that is your bobbin assembly.
When you turn the knob towards you, your needle should dip down into the abyss and come back up- with your bottom thread! HUZZAH! it SHOULD be a loop around your top thread. (I'd use contrasting colors for practice.. so you know what it'll look like)
The manual says to "grab the bottom thread" but seriously, I can't get me fingers down in there, so I just slide some scissors under the foot and between the two sides of the loop, and just slide 'em left. usually works just fine. Unless my tail for the bottom thread is too short, cause then it'll be hard to grab. You should be good to go!
I know this is pic heavy and kind of long, but I like to provide as much info as possible! Let me know if it helped!!
Posted on Jul 31, 2009
SewTechWayne
  • 186 Answers
SOURCE: bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Posted on Jan 29, 2009
Mimito7
  • 128 Answers
SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
Posted on May 29, 2009
WonderTech
  • 268 Answers
SOURCE: I have a Brother LS-2125 and when I try to sew it
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Posted on Dec 30, 2009
  • 1788 Answers
SOURCE: Can I have a FULL tutorial video on how to thread
I do not think that they make a video for your model. You can download a copy of your manual for free, at www.brother-usa.com and then you can enlarge the diagrams. Save it on your computer then you always have a copy. You can also print it out. Your machine is very basic and you will be a pro in no time. Just take your time, relax and be patient with yourself.
Posted on Oct 11, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Threading the bobbin
hi Sharon.
not sure if this will help you out because its saying its for the, ls 2125i.. but try this step by step link.
How to Thread Brother Ls 2125i Sewing Machine
or this youtube video link.
How To Thread Bobbin on Brother LS 2125 Sewing Machine
this link might be the best one for you to watch.when you go to this one scroll down the page a bit and you will see where you can watch the video,
How to Thread bobbin on the Brother LS 2125 sewing machine
Nov 25, 2017 | Brother Sewing Machines
I have a brother LS-2125 and the thread from the bobbin is not catching and is not being pulled through.PLEASE HELP! i need it for an assignment! :)
Here are some things that may fix the problem:
1. First, replace the needle
2. Next, remove the thread and completely rethread the machine
3. Remove the bobbin, clean any lint or thread from around the bobbin, and replace it.
Try sewing again on scrap fabric.
I hope this helps.
Apr 01, 2011 | Brother LS-2125 Mechanical Sewing Machine
Bobbin
Sounds like thread is caught in the shuttle. Check your owners manual, if you misplaced it, go to brother.com and download it or print it for free
Jul 23, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have this machine brother ls-2125.my
You need to either adjust the tension or ensure that you have routed the bobbin thread properly.
Apr 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin case on brother sewing machine
May 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Loose stitch with loops on top of material i got the right needle and bobbins what do i need to do i have ls 2125 brother
General rule of thumb is this.. If it loops on the bottom the problem is on the top..
If it loops on the top, the problem is on the bottom.
Sounds like #1 your bobbin is wound very loosely , #2 your bobbin thread has to go thru its tensioner.
Apr 19, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin holder keeps catchin thread
good luck!
Jan 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother ls-2125
ple let me know LS-2125 what option its have
Feb 15, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
3,696 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
