Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Can not get my adsl modem to connect through ASUS wireless router
I have a Dynalink RTA-1320 ADSL modem and have just purchased an ASUS WL-520GC wireless router to extend internet to all wireless PC's in our house.
The manual sasy the modem is to go in the WAN port in the back, however, doing this does not allow access to the internet. If I were to plug the cable from the modem into the LAN port of the router, it works. Even though this works, I want it to work through the WAN port. Are there settings on either or that can be adjusted to ensure this works (without comprimising wireless netwrok security)?
  • laudonny Aug 31, 2008
    Thanks for the suggestion.  But it doesn't solve the problem.  Is there any other way?
    Novelist:
  • 143 Answers
It could be the modem and the router has the same ip address. the asus router has an ip of 192.168.1.1, check if the dynalink modem has an ip of 192.168.1.x. if so, change the router's ip to 192.168.x.x (e.g. 192.168.2.1) then see if you'll be able to connect to the internet while the modem is connected to the wan port of the router
Posted on May 23, 2008
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Asus WL 520gu can't connect internet
1, connect your wireless router with cable to your laptop,
2. Login into your Asus-WL520gu and setup your wireless how you want it to run." do not bother with putting your username settings in there"
3. In your Asus-WL-520gu after setting up your wireless turn the DHCP off in it.
4. Now connect the cable that you have connected to your laptop to your router instead of your laptop.
""You should now be able to connect to the wireless with your settings. and connect anything ells you want to the other 4 ports on the back of you wireless router"" note: do not connect anything to the WAN port as it is used for DSL modems; and not Routers with ADSL modem.
when connecting a router to a router - the one that is connecting you to the internet needs DHCP turned on because it is the one that will be giving you IPs and Gateway settings - the other router such as wireless router after setting it up needs its DHCP turned off - other wise you will have 2 routers trying to do the same thing with ip's and gateways. And you should never connect a modem router to the WAN port as it is a modem router and NOT just a DSL-modem. The WAN port is intended for DSL-modems only. Not only consumers but also many technicians make that mistake
Aug 23, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
ADSL B or ADSL A connection on the other side ???
configure it manually.
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Jun 18, 2009 | ASUS WL-600g Wireless Router
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
Asus WL-520GC wireless not working....
hi buddy!
first you configure the router to the modem ok
by typing the 192.168.1.1 and follow the instruction ok
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 22, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Wireless wl-500b routing problem
minha internet tá caindo direto e não consigo entrar no modem
May 20, 2008 | ASUS WL-500B Wireless Router
Install prob
I suspect these devices by default may be set to either the same IP address or exist on the same subnet. If you know how to configure the devices you can check. Possibly you can connect a computer to each (when not router and modem are not connected to each other) and issue use the open the DOS or command prompt type ipconfig and press enter to get the default gateway address for each device and report the contents back here. Otherwise you may need someone to lead you through those checks and reconfigure the devices as appropriate.
As a new owner of a wireless router you may also want to consider this as you are installing it.
for general wireless security see
http://www.fixya.com/support/t281214-wir...
Dec 06, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Set up wireless router and modem Linksyss
It is not hard at all, but its alot of typing.
First have you tried following the manual to set it up?
Oct 22, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
600 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
