To reprogram nextech 1519003b
Batteries died, put new batteries in, remote doesn't work, lost instructions, don't know how to set it up.
Thanks Brian
[email protected]
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
  • Anonymous Oct 31, 2010
    Sounds all well and good, but this remote doesn;t have a SETUP button.
    The buttons and their rough layout are as follows (* is Power, in RED on the remote, P is in green, E is ENT, and is 100 . ^ is CHAN , v is CHAN-, L is Last, A is A-B, < and > are Vol- and Vol respectively,T is TV, C is CBL, and M is M)
    T P C
    < M >
    L v A
    1 2 3
    4 5 6
    7 8 9
    E 0
SOURCE:
How do I replace the IR sensor?
If you took the batteries out of your remotes to change them, they possibly lost their programming and need to be reprogrammed. I drop my controller often and have to reprogram it. All of the lights light up but the TV appears dead. Either find your control programming guide or look it up on the internet how to reprogram your remote.
Jan 06, 2015 | LG 42LG30 42 in. LCD HDTV
My remote control (Number KM6820) will not work. I have put in new batteries and the TV. man has been twice to try to figure it out. My television is not so very old - less that a year- so I am...
Have you tried to reprogram the remote to your television set?
sometimes the code that is in your remote will work the set but not work all the options.
Aug 04, 2008 | Televison & Video
Why won't my Infiniti M35 remotes work now that i put new batteries in them?
If the remotes are anything like GM remotes - you will have to reprogram them both. Most Auto-Zone stores will do it for free - if you buy the batteries from them. Or google Infinity remotes and they will tell you how to do it yourself.
Apr 29, 2014 | 2007 Infiniti M35 Sport Sedan
Brand new batteries in my remote. Tried to reprogram. Worked. Remote sperattacly works. 2010 model.
IF you took too long to change the batteries in the remote it may have lost some memory. The remote can be reprogrammed by a service dealer but they will need the remote and the car to do the job.
Sep 11, 2013 | 1998 Ford F150 Regular Cab
My remote car starter from autostart on a grand am 03 won't start or locks won't work after it died for about a week then changed the batteries
Check to be sure the new battery is a good new one, they set on the shelves for some time ya know. Then make sure it goes in the correct direction.Then refer to your owners manual if it needs reprogrammed.
Feb 18, 2013 | Cars & Trucks
I receieved a SYLVANIA 6432GG TV with a remote. The remote control doesn't work. The previous owner had programmed a Comcast remote control to use on the TV. I don't know how to reprogram t
GOOGLE THE MODEL NUMBER OF THE SET (IF ORIGINAL REMOTE) WITH "manual" which would get the owner manual to do this.
Each set is different in this process.
Apr 08, 2012 | Sylvania 6432GG 32" TV
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
I have a universal remote and lost my manual, put new batteries in my remote...and now have to reprogram for my tv can you tell me the code for a sharp tv/vcr combination?
Here is a link to download the manual with instructions for programming the codes:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc4220-manual.zip&area=other
Aug 18, 2011 | One For All URC4220 Remote Control
RCA Universal Remote stopped working
I have the same problem on my RCA UNIVERSAL remote too..any one could me ?
thanks
Jan 08, 2008 | RCA 244889 Remote Control
Televison & Video Logo
412 people viewed this question
Top Televison & Video Experts
Ekse
