Question about Lands Phones
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
  • Anonymous Sep 25, 2008
    I have the same problem with this model.
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Posted on May 12, 2009
6ya staff
SOURCE:
How do I forward my phone number on a Dect 6.0 cordless phone model 30524
Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
Jun 27, 2018 | Dect Lands Phones
I have Uniden DECT1480-3. I purchased two expandable handsets, but I cannot figure out how to get the new handsets to register with the base unit.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!
So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...
Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.
Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu.
Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.
Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!
Enjoy!
May 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
"out of range"
I have a GE DECT 6.0 Digital phone (silver, 2-handset model) and one of the handsets began displaying "Out of Range" and was unresponsive. We've had severe lightning around here in recent days which interfered with the digital tv reception, so I'm pretty sure that's what caused the problem. Here was what worked for me:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
This action re-initiates the transmission between the base unit and the handset.
Jul 13, 2009 | Thomson GE 27907GE1 Cordless Phone
I have a three hand set GE dect 6.0 one of the handsets will not activate, it keeps showing me "Out of Range" I have tried many times to set it up but it always give me the same message "out of range". Can...
On the handset, look for the "PROGRAM" button and choose "HANDSET SETUP". Scroll through the menu to find "REGISTRATION" and select it. The handset display should then prompt you to press and hold the "PAGE" button on the base unit for 5 seconds and then press the "PROGRAM" button on the handset.
Perhaps you've already tried this process, as you indicated your attempts "to set it up". This is what worked for my GE DECT phones when one of the handsets displayed "Out of Range" after an electrical storm. Best of luck to you!
Jul 09, 2009 | Thomson GE 27907GE1 Cordless Phone
My handset has a blinking icon, indicating not close to base
I found the 800 number to call, spoke to customer service, they gave me the suggestion of unplugging the base from the outlet, removing the batteries from the handset, wait 5 minutes and plug in and put in the batteries. Yes, that fixed it. And then the customer service technician called back later to see if it had worked. I thought that was above and beyond the call of duty. Certainly a good way to win customers!
Jan 22, 2009 | Panasonic DECT 6.0 Expandable Cordless...
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
Validation
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Lands Phones Logo
593 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
