HP Photosmart 8150 will not print text when prompted. Paper will shoot out. Will print test pages OK.
  • hrsyba Apr 02, 2008
    Been there & done that. Also did same for my laptop with the same results, Installed same program with laptop. Program installed OK but when I attempted to print text from documents - no response. Yesterday it did print when promted but quit after about 20 pages. I needed to use different icons to print at the time. The it quit.
    hrsyba
  • 19,396 Answers
Does it or does not print ok, please give more info.
Posted on Apr 02, 2008
  • Ginko
    Ginko Apr 02, 2008
    Ok, I understand it does not print from word processor.
    Check that the printer is as default printer in 'insatalled printer on control panel . If not click the right button of the mouse on printer icon in 'installed printers' and chose 'set as default'.
    This should solve your problem.
    Regards
  • Ginko
    Ginko Apr 02, 2008
    If the above still did not solve the problem, you will need to reinstall the printer driver, to do this:
    Disconnect printer from PC
    go to 'installed printers' in 'control panel'.
    Remove the printer from windows (right click and delete)
    Run printer software disk.
    connect printer only when prompted by software setup.
    It should print fine at this point.
    First check setting for default printer as posted above.
SOURCE:
Hi: Re HP Photosmart D5160 printer: 1) Prints a
You may have added a separator page,
1). Open printers and Faxed.
2). Right-click your printer and select 'Properties'.
3). Click 'Advanced' tab
4). click 'Separator Page'
Delete any text in the box and click 'OK'
Sep 13, 2011 | HP Photosmart D5160 InkJet Printer
My HP Photosmart 8150 will only print from the card reader. When I try to print from the computer, it reads "printing" but eventually times out.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Nov 27, 2009 | HP Photosmart 8150 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
Paper jam warning. I cannot find any paper in
Please try to turn off your printer and unplug all the connection in the printer from its power down to its usb or parrallel connection. And let it up to 30 minutes to unplug and turn off. This process is letting your printer reset it self and loading its default and original settings. Usually it loads it original settings. After 30 minutes please plug all the connection of the printer and then turn the printer on and test the printer by printing a document or any files you want to print. Please observe what is the result.
Thanks
Aug 07, 2009 | HP Photosmart 8150 InkJet Printer
My HP Photosmart 8150 has started printing color
You may have a colour management problem. Your monitor may need to be recalibrated from the software you are using to print your images. Your printer too may need to be sorted by calibaration too.
Jun 13, 2009 | HP Photosmart 8150 InkJet Printer
Photosmart printer 8150 won't print anything on paper.
CHECK THE NETWORKING AND SHARING,
WINDOWS DEFENDER,
WINDOWS FIREWALL,
DEVICE MANAGER FOR UPDATE DRIVERS
Mar 14, 2009 | HP Photosmart 8150 InkJet Printer
Unable to print text documents
Some times image/picture files are very big files. That big size, in mega-bytes, some times conflicts with your amount of available memory. It could effect the print que or ram. Try running the file through a picture editing program edit the files then rename and save them. You can check the file size prior and then after you run the file through the program. If the file size is lowered it should print.
Nov 07, 2008 | HP - HP Photosmart 8250 printer
Not printing...
Please print a self test page by following steps. Check all the colors printed perfectly.
1. Press Setup on the All-in-One and press arrow keys to select Print report menu and then Press Ok.
2. Then press Ok again to print a test page from the All-in-One.
Let me k now from which appllicaiton you are trying to print. Let me know if you are able to print normal text documents also color documents or not. Need a description of the issue.
Thanks
Dec 24, 2007 | HP Photosmart 2575 All-In-One InkJet...
106 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
