Question about Optoma EzPro 739 Multimedia Projector
Optoma color wheel issue
I just installed the color wheel and it isn't showing all the colors. Rather, it looks dark or bluish. I saw that you recommended reseting the wheel rate (or something). How would I go about doing that?
Any help is appreciated.
Thanks,
Brad
  • 563 Answers
Hi Brad
You'll have to go into the service menu and check if all the colours are showing the same percentage.
We normally set all of them on 50%
Posted on Apr 02, 2008
  • Tim Dawson May 27, 2011
    *How* to get into the service menu might actually have been a helpful bit of information, but otherwise, this suggestion, while correct, is ultimately useless . . .
Optoma PK301 lost a color
it is not correlated with bulb
1,the color starts to go out, it become the white and black,the color is disappear.
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as 3 sesame seeds
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 10, 2014 | Optoma PK301 PICO Pocket Projector...
HD70 DLP Projector: The projector is used and about a year old. It cur...
Did this start occurring after you replaced the lamp?
The reason I ask is I had the same issue after changing the lamp and it was caused because when I took out the old lamp I noticed dust in the lamp housing which I attempted to blow away.
This caused the problem because some dust got further into the projector, specifically around the color wheel. I sorted it out by taking the projector apart following the instructions here:
http://tantht.blogspot.com/2009/02/how-to-remove-dust-blobs-from-optoma.html
(note my HD70 was out of warranty, if yours is not, I would recommend contacting Optoma to get it fixed).
Follow the above instructions to step 14 and then locate the color wheel which is at the front of the projector behind a dark gray, plastic type square shaped cover.
You have to be very careful here, but remove the color wheel (there is one screw holding it in place) - note it
May 18, 2010 | Optoma HD70 DLP Projector
Color wheel sounds like a buzz saw. Fan is quiet because there is no noise in the cool-down mode. Can this be replaced by user?
Baily, I have had my HC1500U color wheel replaced two times due to the color wheel's unpleasant "buzz saw" effect showing up every few thousand hours of usage. It is happening again for the third time and I am still within Coscto's warranty so I am going to have it replaced again...will never buy a DLP projector again...too many moving parts that can break!
Would love to be able to replace it myself if you ever find a place that sells the color wheel.
Feb 09, 2010 | Mitsubishi HC1500 DLP Projector
Need color wheel for Optoma EP745. Are any available?
Optoma sells a color wheel, same issue I have. Call 888-942-2929 & ask parts to send you a color wheel. Not sure the cost, BUT I read in another forum they are 89.99.
Dec 18, 2008 | Audio Players & Recorders
Bad color wheel on Optoma DV10
Yes, you can replace the color wheel yourself if you are handy with a screwdriver.
Jul 19, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma color wheel
Hi there
You could get one from a Optoma agent.
I can unfortunately not tell you exactly where as I do not know where in the world you are .
May 07, 2008 | Optoma MovieTime DV10 Multimedia Projector
Need new color wheel for EP 759
i would try to email optoma or parts guy localy that sell or fixes these see if he can order u it ok best way thx nick
Feb 12, 2008 | Optoma EzPro 739 Multimedia Projector
Small bluish, black triangle at far right corner
This is the same problem as other posts have mentioned about the right side of the screen having a bluish-balck stripe down the side of the screen. Here's what's happening. There's a small light tunnel which has 4 very small mirrors located just behind the color wheel. The lamp shines light through the color wheel as it turns and the light goes through this small tunnel and is then relected off several mirrors before it is projected through the lens and onto the screen. Optoma apparently did not use a very good heat resistant expoxy glue when they assembled these mirrors and over time the mirrors drop down causing a shadow effect on the screen. It can be repaired without paying some repair shop a small fortune. Previous posts have a solution from another contributer whihc includes photos. I had to repair mine and it's worked fine since I used a decent expoxy to hold the mirrors.
Sep 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
267 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
