I have an HP Pravilion dv8000 and I am wondering of teh cpu can be up graded, if yes, to what power. Also can teh ram be up graded. Thanks Geoff Suton
    Sergeant:
    Champion:
  • 326 Answers
What cpu does it have now?
Yes ram can be upped if U have less than 512 M.
After finding out what cpu and ram U have, check on TigerDirect.com.
Posted on Apr 02, 2008
Laptop keeps shutting down immediately after trying to power up
Check the battery ..If the battery is not capable to keep power anymore..this will happen ..but the shut down will not be instant ..if it is instant than to blame is the cpu cooler ..probably it does not work anymore..and teh cpu gets to teh max temperature right the way and shuts the system down ..To fix that is to replace the fan ..
another thing that you may check is teh ram memory ..sometimes if you make changes on them and they do not match perfect with the rest or so ..it makes issues on boot up .Just remove them all and try them one by one if they are more than one ..This way you will knwo if one is defective ..cause will not try to boot up ..If non seam to be affected ..just plug them well and start over cause it is possible to be just a matter of not making contact well and after you remove and place them back ...to work perfect
Dec 23, 2011 | HP HDX Computers & Internet
Why does my screen only brighten when the ac adapter is unplugged on HP Pavilion dv8000?
That cause by setting at Power Management setting. If your laptop setting is default, LCD back light is 60% if you running on battery and 100% when running with plug in. You also can change a setting at :
1- Go to Control Panel
2- Go to System & Security
3- Go to Power Option
4- Change Plan Setting
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 30, 2011 | HP Pavilion dv8000t Notebook
Where can I buy a lower price HP PAVILION DV8000
It's much better to buy the battery from the manufacturer's website. The transaction is a lot safer and reliable. Take there are two categories of battery the ORIGINAL and REPLACEMENT. Normally the highe mAh capacity has the longer battery life. The price of REPLACEMENT batteries are much lower than the ORIGINAL batteries.
You can view the product on this site:
http://www.shopping.hp.com/webapp/shopping/product_detail.do?product_code=EF419A
Thanks.Cheers!
Apr 21, 2010 | HP Pavilion dv1000 Notebook
How to find and replace hp pravilion 763n battery
give a call to service center
go to computer market to find one of same series
Oct 24, 2009 | HP Pavilion 763n PC Desktop
How about this Pavilion dv8000 Battery for HP Laptop Battery?
You just write down the details about HP pavilion dv8000 battery, I know two websites have cheap HP pavilion dv8000 battery
http://www.cheap-laptop-battery.co.uk/laptop-batteries/hp-pavilion-dv8000-series.htm
http://sales-battery.com/laptop-batteries/hp-pavilion-dv8000-series.htm
Jun 02, 2009 | HP Computers & Internet
No power at all when i try to turn it on
If the CPU (Processing unit) is not switching at all, then first thing you can check is your RAM.
Switch of the power supply and unplug the cables. Then open the top cover (or whatever your CPU has) of teh CPU and remove the RAM from its slot and install it again (place it in its slot as it is). Or if you have 2 slots for the RAM and only one RAM installed then try installing (placing) the RAM in the other slot which is empty.
Plug in all the cables and switch the power supply. This method works most of the time.
Gud luck.
May 04, 2009 | Computers & Internet
Hp motherboard startup problem!!
hmmm my sussgestion in yourr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS (power supply to the board), Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch/Listen carefully:
Case 1: if you can hear a long beep, then your CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch/Listen carefully.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
For your help here is picture of general moherboard with connection details. 86c6af2.jpg
Thanks
Iqbal
Mar 19, 2008 | HP Compaq Motherboard
Replacing cd-rom
u need open the cabinet and there should be a serew and remove it and connect teh new one and make sure teh power and date cable the red side of teh power as well as the red side on teh data cable should face same side and start the pc>and put the cd and install soft ware and start using teh dvd and cd>rate me solved if its helps thx
Nov 16, 2007 | HP Compaq dc5100 PC Desktop
Computers & Internet Logo
David Payne
David Payne
