Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave running although not turned on
My GE spacesaver microwave just started running on it's own. The only thing I used today was the vent fan button while cooking on the stove underneath. Turned the fan off and a few minutes later heard a wierd noise, almost like a timer ticking. That stopped then a few minutes later, it started running on it's own like it was cooking; light on, cooking sound, but turntable not turning. All the buttons appear to work properly. Help!
  • GE Master
  • 9,098 Answers
Thought I had answered this, but this is usually caused by either a bad door switch, a loose door switch mount, or possibly a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 02, 2008
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver JVM140J 001, intermittent Vent Fan on Low
see the next steps for fix it, use the common sense.God bless you
First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start
Aug 03, 2012 | Microwave Ovens
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
GE Profile Spacesaver XL Sensor Microwave
You have a bad door swicth or a bad wiring connector to one of the door switches... secondary swicth or the door sense switch.
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Magnetron cooling fan
Are you sure it is the internal blower and not the VENT fan ?
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
Mar 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable does not turn and fan won't exhaust
The second problem is probably defective door switches, or it may be a problem with the control panel, which we repair nationwide for only $32.50. On my Web site, I have info on safety, disassembly, and diagnosing and replacing door switches: http://tinyurl.com/yzjozk Running it empty has damaged the magnetron. It will work for a while, but it will eventually have to be replaced. A good parts source is here: http://tinyurl.com/gv383
Jan 05, 2007 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
174 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
