Question about Texas Instruments TI-89 Calculator
My TI-89 Dies out fast
I keep buying new batteries for my TI-89 and its getting quite expensive. I was wondering if anyone has a similar problem. I would put in new batteries then the following week the calculator would die. I've tried replacing the replacement battery. If you have any suggestions I'd greatly appreciate it.
  • Anonymous Feb 25, 2009
    i have the same problem on a ti 84 plus it's anoying...
    i just use rechargables
  • 360 Answers
If you download games and some third party software can be running all the time draining your batteries. Some of the APPS with Ti 84 will do the same thing. I'd try and find the problem software and delete it.
Posted on Sep 17, 2009
SOURCE:
TI-89 Titanium completely frozen (Tried all reset methods)
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium.
Or, type diamond key simultaneosly with + or -
(plus or minus) key to resolve dark screen.
Jun 01, 2017 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
I can't differentiate a function and I'm quite
Clearly the x variable stores value zero. Press [F6] ( 1:clear a-z) [ENTER] and restart your derivative.
Hope it helps.
Sep 29, 2009 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
Minimally used calculator drains batteries fast
The draining of batteries depends on usage. Turn calculator off when not in use. Use rechargeable batteries: Have two sets of them and change batteries before the ones in use are not fully discharged.
If you get tired of that, I suggest you have the calculator repaired.
Hope it helps.
Apr 14, 2009 | Texas Instruments TI-89 Calculator
New, barely used 89 drains batteries quickly
Because the games programs are writen badly and are running even when the calculator is off. Battery life will be extended if you get rid of the games.
Apr 14, 2009 | Texas Instruments TI-83 Plus Silver...
My TI-89 Titanium got fallen and it had to black stuff at the top right hand corner. I wonder if i can call the company and get it fixed, I wonder about the warranty of my calculator
In the US and Canada warranty is 12 months from date of purchase. Duration may chamge for other countries.
Try first to determine if is still works (keyboard answers, turns on, turns off, screen is not broken)
If you want to repair it (although I do not understand what the black stuff is) off course you can do so. Compare repair fees with the price of a new calculator, or the price of a similar one HP49G+, HP50g, Casio ClassPad300Plus/330.
Hope it helps
Apr 05, 2009 | Texas Instruments TI-89 Calculator
Ti 89 Titanium Battery use
I have a regular TI-89 (HW2)...have had it for 6 or 7 years. Suddenly it's doing the same thing. I have to put new batteries in it every week or so. I even replaced the backup Li-Ion battery. I'm getting really tired of buying new batteries but don't want to go shell out 100+ for a new one.
Anyone have anything on this? I'm having trouble finding much on this...
Oct 01, 2008 | Texas Instruments TI-89 Calculator
TI-89 Backup Battery
Usually you will be able to re-install everything. And I would try uninstalling the program first then if that doen't work just pull the batteries out and put them back in or just press the reset button. Hope this helps. =)
Feb 24, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
366 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
