Question about Car Audio & Video
1990 ford fairmont with a ford awa radio/tape player. I disconnected the battery to clean it & now have no music! I wrote the number down a put it in my car folder but cant locate it... can anyone help please?
I googled around until i found a free solution...thanks anyway
Posted on Apr 02, 2008
I HAD A NEW BATTERY PUT INTO MY 99 FORD ESCORT zx2 HOT COUPE AND I THINK THEY MESSED UP THE CONNECTER THAT ATTACHED TO MY BATTERY CABLE AND NOW MY CAR RADIO DOSE NOT WORK?
They didn't mess up the connector, you radio has an anti-theft code and it must be put in before the radio will work. IF they would have kept 12volts attached to the battery cables when they replaced the battery all would be well, but once the power is completely disconnecting from the car you must have the anti-theft code for the radio. If you are lucky someone wrote it down in the owners manual if not you will need the serial number off of the radio to obtain it from the dealer.
Sep 14, 2014 | Cars & Trucks
2002 lesaber, tape player c/d combo. when playing tape it says clean player, so i did. tried to hold eject button for 5 seconds, didnt work. still says clean player... how do i make this go away? ...
Try disconnecting the battery negative and positive cables. The radio has a constant hot wire which keeps the memory alive on the radio. This constant wire always has power to the radio so you have to disconnect the (+) for at least 2 minutes, which should clear out the memory on the radio and hopefully it'll stop saying clean player. If it comes back on when you hook the battery back up then look up the radio brand and model number on line and do a search for a way to clear it from the radio.
Aug 26, 2013 | 1998 Buick LeSabre
Hi I have a Ford Fairmont 1995 model sedan car .it asking me for radio security code to enter after i disconnect my battery line. can anyone help me out about that, thnaks!
remove the radio and post the chassis number ,leave your E mail reply from this on your mail then post it when you have the number as i do work and i will not see another general posting if iam working and i will see what my code generator computer can come up with ,look in the boot for a sticker as it may have been put in their when new ,on the sun visor because thats where i write them ,also under the bonnet i have found them hand written ,or go to ford dealer some will do it for nothing ,they just look up the original paperwork
Aug 12, 2010 | 1995 Ford Explorer
I own a 1997 Ford Taurus. I am trying to use a tape to mp3 player adapter in its tape player. When I push the tape in the player, I get a "TDE3" message and the tape spits out. I tried using another tape,...
It's the tape deck there must be a tape that got caught inside and is wrapped around the capstan or the heads and the radio stays on because the switch is not activated by the deck lowering down far enough you have to take it out and clean it and look for any tape or other obstructions that would stop the mechanism from working including the belt you may need parts and a 20 year old radio there hard to find try the junk yard for a replacement but you can operate yours with the cover off if you can get it out far enough to see inside while it's on and that will help you find the problem but first bring it inside your house so you don't loose parts after cleaning with alcohol and derusting if any and a light lubricant you might be lucky see what happens I also use an adapter for my cell phone music in a 2007 bull and I also did it in an 87 bull with a cd player so I know what your talking about also make sure the adapter wire is not hanging up when pushing it in good luck also brand new replacements might be the best way to get the music you want they have auxiliary input jacks for cell phone mp3 players but try to fix yours first the learning part is priceless for the future radios you will own
Jan 04, 2018 | 1997 Ford Taurus
Installing cd player in truck and nothing works on it
You probably blew a fuse in the back of the radio, or in the fuse box. Check both to be sure. And remember, always disconnect the battery before you do something with the wiring harness.
Jun 12, 2009 | 1990 Ford F150
Awa dvd vcr player
The VCR may need a head cleaning. All it takes is a little oxide from a worn tape to clog up the heads and cause the trouble. You can try a head cleaning cassette (if you can still find one), but it's better to open the case and clean the entire tape path with the proper cleaning fluid and swabs. You used to be able to buy all the supplies and instructions in a kit at Radio Shack and other stores. If you can't find what you need locally, there are certainly online sources.
Mar 29, 2009 | Televison & Video
Ford Escort Ghia radio code needed
hi there lizy if you can hold onto till later on i will get your code to you later.
Feb 23, 2009 | 1990 Ford Escort
Radio reset codes
I have a 2001 focus ..radio suddenly stopped playing after being at garage.  I thought that the battery was disconnected and the radio neede reset code, as it has a rad blinking dash anti-theft light.  i went to ford garage and they told me they don't have reset codes on the focus.  Is this true?
Aug 05, 2008 | 2001 Ford Focus
Ford AU11 Fairmont CD Player / Radio
You need some special tools which slot in to the holes at the sides of the stereo, they release some clips and the unit slides out. Then you can take the cover off the unit and remove the jammed CD. These units are notorious for failure, especially the six disc stackers, and are probably not worth repairing, can be more expensive to repair than fitting a decent aftermarket cd player. Most audio installers or your local Ford dealer will have the tools to remove the unit, and if you just want the radio, you could remove the jammed cd and refit the stereo and just not use the cd player. You'll need to get the radio code from a Ford dealer to get the stereo going again if you disconnect and reconnect it. They may need the serial number off the unit to give that to you, and you may need to prove ownership of the vehicle.
Jun 26, 2008 | 1983 Ford Fairmont
Rover 400 series tape radio player
Hi if you radio is a blaupunkt type let me know the serila number bp************ and model number 7 64* **** **** you wil need to pop the radio out to get this information
Mark
Mar 07, 2008 | Car Audio & Video
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
