Question about Brother MFC-9420CN All-In-One Laser Printer
MFC 9420 CN paper tray issue
I came to the defective engine board conclusion as well, and your description of the page count is correct; however, I did not see this anywhere in the Brother Service manual. Any suggestions on where to find a replacement board? I actually found a complete printer for $279.00. I'm going to call my Brother Service center and get a quote on the engine board tomorrow.
Any Idea what conditions cause the board to die? Also thanks for confrming the cure for me.
  • skiddgp58 Jul 25, 2008
    Where can I get a service manual have exhausted all my sources. Scott
  • Anonymous Feb 19, 2009
    i have already replced the opc belt and fusing roller. I am not spending another 400 to replace this stupid engine controller. The machine is just 2 years old.
  • 3 Answers
Look in the parts manual for "engine controller board." You can get replacement boards through at least some of the authorized service centers. I got a refurbished board from a good guy in St. Charles, Illinois (Tom). You can contact him by email. [email protected].
I'd shy away from buying a complete printer. No guarantee it has an updated board and then you'll be back to where you started.
I'm pretty sure the board dies from a firmware bug that's been dormant until recently. Not sure if the bug is triggered by reaching a certain page count, date, or something else, but if you notice, the reported problems all seem to be emerging within a few months of each other even though the printer was first released more than two years ago. Generally after the warranty expires.
Posted on Apr 04, 2008
SOURCE:
I have colored smears on left side of all my printed pages with my Brother MFC-9420 CN. What causes this?
It's not unusual for paper to hit the bottom of the print head, especially if the paper is bent. This can cause smearing. If you have pets, you can check for pet fur in the printer, or other foreign material inside that can also cause smearing.
Sep 11, 2014 | Brother MFC-9420CN All-In-One Laser...
Brother MFC 9420 says:reinstall tray#1, never goes to ready.
Here is a solution I found posted by Razor. (It turns out my engine controller board is bad.) Good luck with yours.
On your control panel, press "menu/set" "7" then "2". if your page count shows 288,888, you have a bad engine controller board. anything other than that count, most likely is a damaged paper cassette. there is a tab on front left side that is probably worn or broke off.
May 01, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper Tray #1 error message
on your control panel, press "menu/set" "7" then "2". if your page count shows 288,888, you have a bad engine controller board. anything other than that count, most likely is a damaged paper cassette. there is a tab on front left side that is probably worn or broke off.
hth,
razors
Feb 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Parts for a brother MFC-7420
you better double check that model number. i'm thinking you mean the mfc 9420.
razors
Feb 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Printing fax
take the paper tray out and shut the machine down also cancel out any printing in the cpu then reboot the printer good luck
Jan 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
MFC -9420 CN Printer/Fax Scanner
I've seen this before...
The machine is calling for legal sized paper and it thinks it has it in the paper tray. Check the back stop that is inside the paper tray. It should be a green guide that is closest to you if you pull the tray out. You may have to lift up a flap on the end. Make sure that the paper stop is on the correct paper size for what is in the tray. Hope this helps. Let me know if you need any more assistance.
If this helps you please rate it as Fixya!
Nov 25, 2008 | Brother MFC-9420CN All-In-One Laser...
Problem with Brother MFC-9420CN
This happened on my MFC-9420CN. It turns out the there are blue tabs inside the paper tray that hold the paper in place. If the tabs are not touching the paper, you'll get this "Check Paper Size" error. The printer thinks that you have loaded a different paper tray.
Don P. Greensboro, NC
Nov 07, 2007 | Office Equipment & Supplies
Brother mfl- pro suite mfc-9420 cn
reinstall printer driver or download printer driver by searching web TYPE IN : printer driver for Brother mfc-9420 you need to know what operating system you use on computer like windows xp, windows 2000,or windows 98 download driver and install then retry printer.
Nov 01, 2007 | Office Equipment & Supplies
My brother MFC9420cn has error mssg " check tray #1"
Check the total page count in the menu. If it reads 288888, you have a defective engine board and it needs to be replaced. It is neither a driver issue nor a problem with the paper cartridge.
Brother will quote you a price in excess of $600 for a new engine board, but some authorized repair shops can get them for less than $200.
Oct 26, 2007 | Brother MFC-9420CN All-In-One Laser...
Re install tray will not clear
OK, we never found a battery locally, but we tried something else. WE removed the battery and left it out for several hours. Our thinking was we were trying to reset the memory somehow. Well, it worked. We put the same battery back in hours later and the check tray msg. went away. The printer still works fine almost 24 hours later.
Oct 23, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
218 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
