Power is connected to unit. Flashing standby but will not turn on. Marantz SR4002 receiver.
  • 4,234 Answers
The unit is in "protect" mode. This means that there is a problem in the final output section. The most common fault is bad output transistors. Expect a parts cost of abput $15-$30 in parts plus the local labor rate for a repair cost.
Dan
Posted on Apr 02, 2008
Power light flashing
Press s.speaker b, att, and exit in 3 sec
Feb 09, 2014 | Marantz SR4002
Marrantz sr4002 blinking stand-by button
If you've checked all your speaker connections and there is no short, reset the amp by holding down the "S. Speaker B", "ATT", and "EXIT" buttons for three seconds.
Jan 20, 2013 | Marantz SR4002
Standby button will not turn off
That's why it's stand by button... it is standing by.
Aug 28, 2011 | Marantz SR4002
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
Standby light blinking
if you have the blinking led problem on your SR4002 receiver, it is in protect / safe mode 1- turn on you receiver2- hold 'S speaker B' + 'ATT' + 'exit' buttons at the same time for 3 seconds3- it should turn back on normally
Feb 26, 2011 | Marantz SR4002
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
Cannot get jamo 250 subwoofer to work via marantz SR4002. Have power but no sound. Also are trying to connect PS3 via HDMI which is no probs however, cannot connect via optical audio
hdmi has digital audio in it. no need for optical from same device.
check menu settings in receiver to activate sub, set crossover point and levels
Nov 02, 2009 | Marantz SR4002
Marantz sr4002 amp standby light flashing
did you ever find a solution? I am having the same issue. rabigelow@gmail.com
Sep 06, 2009 | Marantz SR4002
Marantz SR4002 - blink standby
pull the power for about 15 minutes, then plug it back in and try it again, if still no work, then you need to get it looked at by marantz...
Feb 19, 2009 | Marantz SR4002
233 people viewed this question
 Grubhead
Grubhead
