Mitsubishi sl2u projector fault
Temp led is flashing at start up so fails to start cannot find a diagram or service manual for it on the net
  • 563 Answers
Hi there
If the temp light is showing from startup and doesn't fire up at all - you might be facing a Mainboard fault.
This will need either repair or replacement.
Must warn you that the replacement of a Mainboard is very expensive.
Posted on Apr 02, 2008
Using the projector with an acer 500 tablet
Not sure the problem set the tablet resoulution to 1024 by 768
Oct 17, 2013 | Mitsubishi Xl1xu/sl2u Lcd Projector User...
How to check lamp timer
Bulbs do not really have a certain lamp life they only have a lamp timer. You will want to be sure you can get a replacement lamp they can go anytime between 0 and 6000 hours.
Apr 22, 2013 | Mitsubishi SL2U Multimedia Projector
How do i reset lamp
Power on the projector. Press the left and right arrow keys and the power key on your remote to reset the lamp timer. The three keys must be pressed simultaneously to reset the timer.
Read more: Mitsubishi SL2U Bulb Replacement Instructions '
Dec 19, 2010 | Mitsubishi SL2U Multimedia Projector
Whear is mitsubishi projector service center in mumbai
The projection screen contains uncountable tiny black dots which are clearly visible but not ignorable.
Nov 21, 2010 | Mitsubishi SL2U Multimedia Projector
Mitsubishi SL2u projector: Projector was recently dropped and now within 10 seconds from turning it on the Lamp - Temp indicators turn RED and the system shuts down. I suspect a thermal switch of some...
I suspect the lamp cooling fan. Check the fan for debris or damage. If it were the sensor, it would be showing fault mode and not even start up. Hope that helps.
Nov 16, 2010 | Mitsubishi Office Equipment & Supplies
I have a Dell 1800 MP that will not power on. When plugged in the power button, lamp light, and temp light all flash amber. I have read my manual and it shows nothing for when all three lights flash. Can...
The projector can fail to start and the power and temp lights will blink orange. This is a known problem with the Dell 1800MP projectors caused by a failed capacitor in the power supply. You can fix it yourself if you know how to use a soldering iron and have some experience with electronics. There are other posts on the Internet that show or point you to the repair. Search on Dell 1800MP power supply failure. If not willing to attempt the repair, I will repair these projectors for you at a cost of $40 plus actual shipping from me to you. You would pay the shipping cost to me. Considering the effort it takes to repair one of these units, this is a fair price. Dell charges $250 for the repair plus parts. I have repaired numerous of these units with 100% success. My occupation is working as a power supply designer for one of the largest manufacturers of drivers for LED lighting.
Oct 28, 2010 | Dell 1800MP Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
539 people viewed this question
