Question about Olympus Stylus 740 Digital Camera
Underwater photography problems with MJU 740
Got Mju 740 with u/w housing. Have also used UFL 01 u/w slave strobe. Set on u/w macro or u/w wide2. About one third of 200 shots are under exposed - i.e nearly black. About another third are very grainy - as tho ISO set to 1600 . Rest are OK.
Shots taken with a mju 700 in the same situation are uniformly great. any ideas?
  • nick189 Apr 02, 2008
    Thanks - Let me explain again.
    Weeks diving with two cameras - mju700 + mju 740, both with correct olympus u/w housing - swapping the ufl-01 flash unit between them. Wife with one, me with the other and swapping cameras on a dive by dive basis. Same depths and light conditions for both.
    Both cameras always set on automatic mode - either u/w macro or u/w wide.
    Mju700 = 400 great shots
    Mju740 = 400 shots - grainy/black/ok in equal proportions. Mju 740 pics out of water quite OK
    I'm thinking camera fault but don't know how to prove it...
    Thanks - no they're both the Olympus housings - PT 32 and PT 34
    I'm tending to think that it's a camera fault but can't understand why the above water shots are all OK...
  • 871 Answers
Ok,
you dont have any problems with your camera right? all you need is explaination why some pics are exposed, grainy and ok.
well, its easy enough to answer.
where and when have you been doing /taking thse pictures with "exposed" effect? same for the ones that are " grainy" and those that are ok.
i assume that you did not used all at the same time right?
it is an environmental problem. you have not set your cameras setting to coincide with the environmental factors which may bring a big effect on you photos.
with regards to IB4G2008 and sweet_rascal ,
you might have probably used it in manual mode and not in automatic mode which you camera itself will adjust to the environmental settings and everthing like ISO,focal length, clarity issues, blurr...etc.
so as an advise, try switching to automatic mode.
thanks for using fixya
Posted on Apr 02, 2008
  • 1 more comment
  • earl norman llanera
    earl norman llanera Apr 02, 2008
    ok, thats good enough explaination for the other camera.
    since same light conditions and depths, we can assume that the camera mju-740 has trouble with its lens. it may be mechanical or it may just be with the camera itself. but what i could advise is that have the camera checked out in a camera center which also have camera repairs and maintainance...
    hope this has given light to your problem.
    it may also be a possibility that the camera mju-740 has an un-pressurized lens housing . since you went diving...i forgot that. haha. anyway. that would probably be the cause also.
    again, the above camera shots are indeed well because unlike underwater. pressure builds up.
    that is the main reason why there is a difference when taking pics underwater and above water.
    thanks for replying. if you have anymore questions, please feel free to post them here..
    thanks for using fixya.
    Guru:
  • 1,894 Answers
Use the camera in auto mode and try it..
dont go for manual modes..
  • dewan nafees ahmed Apr 02, 2008
    ya that s fine.. use a auto mode..
    choosing UW macro mode will automatically enable flash.. so i think the problem is lying in two things..
    1--> shutter speed.
    2--> your ISO settings.
    for iso settings try keeping it neither too high nor too low..
    keep below 800.. above 400..
    @early
    thanks for correcting..
    Genius:
  • 3,587 Answers
Hmmm..well...let's see...poor resolution comes from one of two sources.
focal lengthe issues..
ocular clarity.
guess we'll try focal length...did you check to see that the housing and the lens are compatible, and perhaps you are experiencing refraction 101?
SOURCE:
I have purchased an Ikelite AF 35 strobe to use with my Sony DSC-TX1 camera and underwater housing. Even with the strobe set to the lowest setting, the photos I take with the camera set to 'housing on' are...
akdenny, have an af35 myself and know from experience the issue is very likely to be the way you have the block out for the cameras flash. if you block it by having the tape inside the housing it confuses the af35 to fire at a higher setting. from what i can gather it senses the strength of the camera flash and adjusts. I get the best results with the blockout on the camera supplied diffuser, stops the flash camera going forward and gives plenty of light to get the af35 to fire right. to blockout i just use some black tape , fabric tape seems to stick well.
you will still need to set the auto level setting.
hope it works out, i find it a great flash. and the guys at ikelite very very helpful.
Dec 28, 2010 | Ikelite 4035 Left Hand AF35 Auto flash kit...
Mju 400 slow down with 2GB xD-PicCard?!?!
It's possible that your camera, being 7 years old, was never designed for a 2gb card. You can find cards of all sizes at amazon.com
Jun 15, 2010 | Olympus MJU 400 Digital Camera
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
My camera takes a long time to focus and take a photo! Why is this?
Hi there can you please select the camera mode in AUTO focus and click the photo. If its in macro photography mode that time it will take time for focusing. If you face the same problem in auto mode also then the lens guide pin is damaged & thats why you face that problem. Thanks & waiting for your feed back.
Mar 23, 2010 | Olympus Mju Tough 6000 Digital Camera
My Olympus 1050sw focus and auto-focus won't work. All photos are blurred.
You probably have macro mode on (a flower symbol is visible in the config menu). That means the focus has been modified to take close ups. Disable the macro mode and your focus comes back.
Oct 01, 2009 | Olympus Stylus / mju 1050 SW Digital...
Camera stopped operating
Well I know what the review says about underwater to five meters http://www.ephotozine.com/article/Olympus-Mju-725SW
but I would take it with a pinch of salt frankly.
You could get onto Olympus and tell them you know- 'You said I could take it under water - now it wont work' - They may replace it
Jul 12, 2008 | Olympus Mju 725 SW Digital Camera
Disable Powersave mode
i have a mju300 with the same housing.when i put the camera in the housing it is on but i turn the screen off.this is the button that is next to the screen and next to the ok button.when i want to use the camera i just turn the screen back on.
hope this helps
adrian
Apr 14, 2008 | Olympus MJU 400 Digital Camera
Olympus Stylus 740 Digital Camera Logo
189 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
