ASUS MyPal A626
Problem for ASUS MyPal A626
ASUS MyPal A626 Wouldn't boot
By Krispoo on Apr 02, 2008
My ASUS MyPal A626 suddenly stopped booting up. Tried to reset it and it would go through the ASUS screen and start into the Windows Mobile startup screen -- the go black. Attempt to restart would only result in the blue LEDs on the selector panel blinking. I tried resetting several times, tried removing the battery several times, same thing. Then, just as suddenly as the problem began, it vanished. Is this hardware or software and if the latter, waht can I do to avoid it again?
Clarification Request
Posted by Ansicht on Dec 15, 2008
After c:\usbloader nk.nb0 comes massage (usb pipe opening error)
What it means and how to solve this problem? I have A696.
Same Problem
Mar 18, 2009
-   I was upgrading the firmware but at some point it failed and the screen just frozen. Then I re-started my A626 but can't boot. I think people out there had similar problems and just want to know how you guys fixed it eventually. Please tell me the steps and I tried to implement it.
Thanks.-   big_hkkid
Feb 20, 2009
-   After a firmware update failed I tried to restore using solution nr. 3. It says:"C:\>c:\usbloader nk.nb0
# USB image transfer tool for Intel PXA27X USB Development Board #
# Version: 1220'04 Author: O.C #
try to open \\.\wceusbsh001
try to open \\.\wceusbsh002
try to open \\.\wceusbsh003
try to open \\.\wceusbsh004
try to open \\.\wceusbsh005
USB pipe opening error
C:\>"-   amavio
Sep 25, 2008
-   the little switch on the side was the key. Makes sense -- its job is to blank the screen, creating the impression that the unit is off even though it is on.-   Guest
Aug 28, 2008
-   tried to turn on after charging. lights blink but will not come on. tried to reset and take battery out with same results.-   wawilson
May 04, 2008
-   I am having the same problem. The ASUS screen comes up then right when it goes to windows it blanks out.
-   Guest
Best Solution
posted on Aug 21, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thank you this helped me repair my A626
Solution #2
posted on May 04, 2008
Very Helpful)
pakua
Rank: Apprentice
Rating: 96%, 14 votes
On the right side of your ASUS A626 there is a switch that says "HOLD". Make sure that isn't flipped on.
-Sean
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Nov 16, 2008
Very Helpful)
whenindowt
Rank: Apprentice
Rating: 100%, 3 votes
If your Asus MyPal a626 ends up as a brick because of a failed upgrade, etc. This will restore it as a new device. I assume you have lost everything and it won't boot, soft reset or hard reset. It worked for me on 11/16/2008. Use at your own risk.
The 696 file works on a 626 just fine.
download A696_dump_wm6_2_eng.rar file from here.
http://www.mediafire.com/?czeymj2nl5x
download usbloader.exe program from here
http://www.mediafire.com/?fa9a9vp2knb
download winrar from http://download.com
and unzip A696_dump_wm6_2_eng.rar file from step 1 to nk.nb0
copy usbloader.exe and nk.nb0 file to c:\
Connect usb cable to a626 and pc
On a626 hold power, launch and reset to go to USB mode
from command line run c:\usbloader nk.nb0
if you have problems getting the a626 reconized as a USB device, try other usb ports or a different pc.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for ASUS MyPal A626
Questions and Unsolved Problems for ASUS MyPal A626
Do you recommend ASUS MyPal A626?
Answer
Answer
im tryna use the mobile internet explorer program, and im connecting to my colleges wireless... (More)
Answer
unable to connect ASUS mypal to the internet, says connecting but never does
Answer
I need to get a new battery cover for my ASUS A626 - the one that came with it fell off and was... (More)
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
