Question about SanDisk Sansa e260 MP3 Player
Dead battery i cant find a ac adapter or moble adapter for this.i have a number for it 9209-snapd.
  • Jean Sintulaire May 11, 2010
    You are looking for the AC adaptor?
    Novelist:
  • 142 Answers
According to the manual, this item can be charged by placing the unit into the docking station and plugging it into the USB port of your computer. The computer can charge the item for you.
The only other way I can think of is if the docking station has a DC input jack available and describes the required voltage for charging the player. If this is the case, you can go to your local Radio Shack and pick up an AC/DC converter with the correct voltage rating and plug it in that way.
Good luck.
Posted on Apr 02, 2008
Power problems
Unplug the AC adapter (Charger) from power. Unplug the AC adapter from the laptop.
Remove the Battery.
Press the Power On button in, and hold it in for a count of 10 seconds.
(And I mean 10. Count, 1001,..1002,..1003,..etc)
Reinstall the Battery. Plug the AC adapter back in. Plug the AC adapter into power.
(ALWAYS plug the AC adapter into the laptop FIRST, then plug the AC adapter into power.
Why?
To avoid a voltage spike at the laptop)
WAIT 1 minute, turn the laptop on.
Still no?
Then the AC adapter needs to be checked, to see if it is putting out the correct voltage.
Don't know, Model Number wasn't stated.
AC adapter checks out, then it is on to the DC Power Jack.
The jack on the laptop (DC_IN) that the AC adapter plugs into.
What style?
Don't know the Model Number wasn't stated.
DC Power Jack checks out, then I suggest you have a problem with a Power MOSFET,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
(Model Number is on the Bottom of the laptop. Plus, this IS a Dell, right?)
Post back in a Comment.
Regards,
joecoolvette
Feb 19, 2013 | Dell Inspiron Computers & Internet
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
Totally dead, replaced ac adaptor, which was dead too, did not help. still dead.
Hello, I am thinking that your battery needs to be replaced as well. Possibly because of the stress it took from your ac adapter issues. So, to check to see if the issue at hand is now your battery... 1) UNPLUG THE AC ADAPTER FROM THE LAPTOP. 2) REMOVE THE BATTERY. 3) PLUG THE AC ADAPTER BACK INTO THE LAPTOP 4) TURN IT ON.
If the battery was now the issue, your laptop should have turned on at this point.. If it did NOT turn on, then there is a different issue that we should troubleshoot. Let Me Know, ok?
Sep 10, 2010 | HP 6530b Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Battery or ac adapter problems?
Sounds like you were cheated out of your money. Hopefully you just need to replace you Power Supply Cord and it will work fine because my guess it has broken wires and that caused the shutdown. If this does nit work, Your motherboard has been short circuited and this will never be fixed, it needs to be replaced and this is costly so it may be better to get whole new laptop. Buy a new Power cord and maybe a new battery if you feel you need to, but if they don't work, your laptop is dead
Nov 21, 2008 | HP Compaq Evo n610c Notebook
Battery compartment disconected by the AC adapter
That could be any number of things. Broken solder joint on the board where the battery terminals connect, dead batteries, and now that I think about it, if the connection is broken or loose in any way inside the hole where the ac adapter goes, it's not going to work with batteries. It needs that completed circuit regardless if there isn't an ac adapter inserted.
Jul 14, 2008 | GPX CDPW8806 Personal CD Player
No power
You sound like you have either a dead power supply inside or a dead motherboard. Best thing is to open it up and test each. replace the culprit.
Feb 18, 2008 | Compaq Evo N610C Notebook
Compaq presario does not turn on
Your battery is dead. You need to get a new power adapter. The battery isn't charging. The AC adapter went south. If the laptop is under warranty, you can get one from Compaq. Or, what I would do is shop on the internet and order one. Whats the numbers on the ac adapter? I'll help you find one.
Jun 30, 2007 | HP Compaq Presario V2000 Notebook
SanDisk Sansa e260 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
