Question about Toshiba 46HM95 46" HDTV
Toshiba 46HM95 Buzzing
I have a 2 year old Toshiba 46HM95. There is a loud humming/buzzin noise, but the picture and program sound have not been affected. It seems to be coming from the vent area in the back. After the t.v. is turned off and cools down, the noise stops. Suggestions?
  • 2 more comments
  • Anonymous May 22, 2008
    I have the same television, mine is apx 4 years old. I had the same issue, I had to replase the unit that the lamp plugs into. Mine was under warranty so I couldn't tell you how much it was, but the toshiba customer service line is very helpful.
  • LadyAcct Jun 17, 2008
    Had this problem in January on my 2 y/o set. As time went on, the buzzing would start sooner and sooner after the set was turned on. Turned out to be the optical engine, which had to be replaced. There was an issue getting the replacement part from Toshiba and it took about 7 weeks, but once the part came in, it was only a couple of days. Fortunately, I'd purchased the extended warranty, because the service guy said the charge was $800. Good luck.
  • xray99 Jul 17, 2008
    I have a two year old 46HM95 the cooling fan has become loud and it kind of hums or buzzes.There are no other noticeable effects on the performance of the TV.
    I have tried cleaning any dust that has accumulated around the fan or any areas where the fan may be drawing air from.The noise remains the same.
  • rlrcstr Feb 13, 2009
    Buzzing sound just started today. The sound stops immediately after turning off the TV. Still trying to figure out exactly what the problem is.
    Problem Solver:
  • 3 Answers
Had tech come in in 2008 an look at tv they told me that the humming noise is from the cable card slot even though the card is not in the slot it will always run to keep the unit cooled down you can replace but after a year it will start up
Posted on Feb 23, 2010
    New Friend:
We are experiencing the same problem. we just put a new lamp in and right after we turn the tv on it hummmmmms then we cut it off and it hmmmmms for about 5 mins then just stops any suggestions
Posted on Feb 21, 2010
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Posted on Apr 07, 2008
SOURCE:
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Turn on TV hear a buzzing and then the TV cycles off and on again
Hi,If it seems you are experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.I found it with complete light engine assembly here: http://www.discount-merchant.com/TOSHIBA-2973026206-p/1160068.htm?Click=48173
Apr 16, 2010 | Toshiba 46HM95 46" HDTV
Loud humming noise when you power on the toshiba
Good Day,
It sounds like you have Color Wheel That Going bad To verify disconnect cable Color Wheel ***'y. NO noise= bad part.
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 50HM66 52" Television
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Humming noise in Toshiba television
my 46HM95 was humming also, I have the extended warranty and the company came out and diagnosed it as the light engine. the part was backordered and it was just fixed today, it was ordered back in February. Problem was solved.
Aug 12, 2008 | Toshiba 46HM95 46" HDTV
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Toshiba TV 46HM95
tv has a bad color wheel
Dec 28, 2007 | Toshiba 46HM95 46" HDTV
Television problems
Have the speakers ever been played loudly? They may have been pushed passed their capacity, in which case, it may be time for a new tv.
Dec 16, 2007 | Televison & Video
Toshiba 46HM95 46" HDTV Logo
741 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
