Audiosonic TV - Word "Factory" appears on top left corner
The red colour on the tv disappeared, that has been fixed and colour is fine now but there is the word factory in the top left corner that won't go away. Since this word has appeared the remote won't work either unless you turn it off and then back on.
  • 2 more comments
  • charliehorse Apr 29, 2008
    power reset,read mannual no solution,checked menu and trouble shoot guide.have a new universal remote and still can't get any joy.May open it up and get nasty with it...must be a solution to this .Who makes these surely they must know?
  • shereer May 01, 2008
    they are made by a company called Yale Appliance Group. They are an australian company. I have been keeping an eye on their website but it has been under construction for weeks now. There is a contact number in new zealand and australia if you are interested just google the company name. I can't seem to get hold of anyone.
  • JayTea Jun 14, 2008
    I have the same problem. It just appeared from nowhere and I have tried everything to make it go away but it sits in the top left corner and ruins the TV experience.
  • shereer Aug 31, 2008
    I finally have a solution for this problem. Finally got my tv back to normal.
    Try this:
    Make certain the TV is receiving a signal.
    Press in sequence on the remote [MENU] > [6] >[4] > [8] > [3].
    [FACTORY] is displayed.
    Press the above sequence again to enter [White Balance] menu.
    Press the above sequence again to enter [Adjust] menu.
    Press the above sequence again to exit service mode.
Try pressing the RETURN button (above the DISP button - number 6 on the button list in the manual). The button has two arrows chasing each other. It worked for me on our Audiosonic KMC TH68 TV.
Posted on Jun 19, 2008
I have audiosonic colour television KMC TH68. The word "Factory" appear on the top just on the middle.The worse part is that is locked. One symbol like "lock" is on the left buttom in...
finally have a solution for this problem. Finally got my tv back to normal. Try this: Make certain the TV is receiving a signal.
Dec 09, 2010 | Televison & Video
Colour wierd in corners of screen
do you have any speakers or magnets on top or near the tv.......if so move them away from the tv...thanks
Jan 04, 2010 | JVC AV-20F476 20" TV
Long wait when cold for tv to actually switch on
bad capacitors unplug the tv and let it sit for a day. Lay the tv flat and take all the screws out the back you want to look at the top right corner of the pcb ( power board you cant miss it ) you will probably notice 4 swollen / leaking caps replace these and the tv should work fine. The tvs protection circuit is stopping it from starting your straining the PSU by using it with the caps blown if your not comfy soldering phone a local electronics company im sure they can help you out. you can easily disconnect the headers from the psu board and take that for repair.
i used 35v 1000u caps the caps i removed were 10v 1000u
Apr 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have a "craig" tv and the word factory is on the upper left corner, when this word appears i can no longer use any buttons on my tv, how do i fix this?
Dec 24, 2008 | Craig CTV-41904 19" TV
Audiosonic Tv
Try hitting the RETURN button - that is the one with two arrows chasing each other just above the DISP button. This turned off the FACTORY text on my Audiosonic KMC TH68.
Apr 01, 2008 | Car Audio & Video
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Wharfedale TV/DVD combo
Contact agent for the unlock code.
Menu and 4 digit code unlocks factory default.
Problem is caused when wrong sequence of keys on remote is pressed, part of parental control.
Oct 15, 2007 | Televison & Video
32" Zenith Television
This is due to electromagnetic field affected in the corner area. Check whether there is any magnetic components in surrounding area if found keep away from TV. And then switch off the TV and remove the mains plug also. Switch on the TV after 30mins. The colour will disappear. Even you got the same problem call technical person. Because the decaussing section is not worked.
Sep 05, 2007 | Apex Digital AT2008S 20" TV
Televison & Video Logo
757 people viewed this question
Top Televison & Video Experts
Electro Med Services...
