Question about Dryers
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
The dryer gets clothes caught between the drum and the plastic part at the top of the dryer. I made sure that the bearing was okay in the back of the unit. What do I need to replac to repair the problem?
Thanks,
John P.
  • 1 more comment
  • Anonymous Apr 29, 2008
    if you open the door and push the drum backwards you can get your clothes out with out tearing them. does it squeak real loud? there seems to be friction plates that the drum rides on that wear out. im in the process of seeing if the friction plates are worth replacing.
  • Anonymous Jan 12, 2009
    I have the same problem. I have countless clothes with burn markes on them from getting stuck at the top of the dryer between the inside drum (is that what it's called?) and the outside of the turning part. The clothes twist and twist and then overheat and burn. All the burn marks on the clothes look the same, a sort of dark brown bow look with twist marks in the center. I've called GE. This is their problem to fix. My dryer is less than 4 years old and I do not expect to buy GE appliances as disposable items every 5 years. I have not gotten any satisfaction from GE cutomer service. Please help! I'm afraid this is going to be an expensive repair if I have to pay for it myself. Also, this dryer is a gas dryer.
  • veneziav May 15, 2009
    GE Frontload gas dryer traps clothes between the drum on top and a small hole that keeps spinning while the clothes are stuck and the clothes usually end up with a grease spot and if they have strings like sweatpants or hooded sweatshirts they twist and twist until they break.
2 Suggested Answers
  • 126 Answers
SOURCE: NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Posted on Jan 07, 2009
Leaving spots on clothing
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Dec 24, 2010 | Kenmore Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Clothes getting stuck
check the top drum slides and tub bearing slide support. it is made of plastic and when it or the slides wear out the drum will drop down enough for clothes to start snagging
http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=395857&ModelNum=NWXR483EG3WW&mfgModelNum=&ManufactureID=2&Selected=00125553i02&Position=3&mfg=GE&Type=&Mark=3
May 28, 2010 | Hotpoint Ariston NWXR483EGWW Electric...
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
My hotpoint model NVLR333ETOWB, will not rotate drum
sounds like the belt is loose from a defective idler pulley
Oct 24, 2009 | Hotpoint NVLR333EE Dryer
Clothes getting caught between drum and front of dryer
Hello Friend, This problem is real common in Hotpoint/GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Jun 29, 2009 | Hotpoint NVL333EY Electric Dryer
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
My dryer squeaks and keeps eating the clothes and leaving burn marks on spots on them because it gets caught in the turn part of the dryer, it is a hotpoint electric dryer, what can cause that?
Squeaking is the rear drum bearing. The rest is the front drum slide supports. After a number of years, these wear and need replacing. Without the model number I can't give you the part numbers that fit your machine.
May 07, 2009 | Hotpoint NBXR463EBWW Electric Dryer
I have the same dryer doing the same thing. Open the door and take the two screws out and lift the top. Remove the two screws that hold the front on. Remove the front. On mine both the plastic parts that stay on the front when it is removed are cracked and needing replaced. I found over 20 buttons that the dryer had pulled off clothes stuck in the front door. I'm sure if it will be cost effective to buy both these parts or not.
Jan 13, 2009 | GE DBXR453EV Dryer
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
511 people viewed this question
Top Dryers Experts
