Play motor bushings
This reel to reel deck needs some play motor (it has three) bushings.
When I opened it up to clean it I realized the dragging effect, in play, was being caused by these bushings being so worn out. Where can I find
these Parts?
    Novelist:
  • 142 Answers
I was able to find my motor parts on E-bay, but they're not there all the time. I've also had luck contacting the original manufacturer and requesting replacement parts. If nothing else, they should be able to guide you where to go.
Posted on Apr 02, 2008
SOURCE:
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
Tape ribbon catching and snagging when on PLAY then it switches off. will not play at all.
The tape will have problems due to three possibilities. Dirty parts such as the Capstan shaft (spinning metal part) or the Pinch Roller that is made of rubber. and also the third item can be the lack or intermittent take-up from the reel drive system. This can be caused by a dead spot on the motor or a crack in the tire on a idler wheel. The unit need service by a person who works on them to resolve your problem. These decks are expected to be cleaned every few hours and those that do not ever do that then have their tapes eaten which is their own fault
Sep 30, 2013 | Audio Players & Recorders
Reel to reel will not play
You do not mention the brand or model number which to answer the question effectively is needed- different machines are designed in different ways. The function of the fast wind and the play mode only differs in that in play a capstan is involved that regulates the speed and the reel motors just do the take-up of taper and a little back tension for the supply reel. You may have either a sticky Pinch Roller linkage or a non- rotating capstan shaft that might point to a loose or broken capstan drive belt. There are also the condition of the Pinch Roller surface and the surface of the Capstan shaft that can be glazed or rubber hard and non-compliant. The rubber Pinch Roller can be re-rubbered, the capstan shaft can be reconditioned and the Capstan Belt can be replaced. Capstan bearings and motor bearings need oil once a year as well. I hope this helped to some extent- I have been working on decks now for better than 40 years.
Dec 12, 2012 | Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I have a pioneer CT-F900 cassette deck, when I press play the reel side that should take up the slack stops and the tape bunches up and the drive mech disengages. The tape stops. Your help, please Steve
The take-up reel is dragging or the belt is stretched or broken. No surprise on a deck this old. Try Fast Forward. Try Rewind. Same result?
If it still doesn't work, and it happens with only one cassette, rap the cassette's flat side against a solid flat surface to loosen it. Try again.
If you're really an old-school deck user you probably know how to cheat the transport with no tape resent to make the capstans engage for cleaning. Try that. The two reels should spin opposite as if maintaining tension. If the right one is stationary or lethargic (try to feel how strong it pulls compared to the left one), there's a loose or broken belt.
Next step. Get out the can opener, go inside and see what's wrong. Good luck.
Dec 25, 2010 | Audio Players & Recorders
A 303 cassette deck - the belt has been changed. The feed spool and capstan turn fine. The take up spool does not turn and play stops after 5 sec. Take up spool is fine in fast forward. Help !
This is a case of a failing reel motor. What happens i sthe brushes become aged and wear down and the motor has what they call a dead spot on the Commutator. The motor will work fine at high speeds as the inertia is working for it but when you use a slow speed as in play mode the motor hits the dead spot and stops. You will need a new reel motor in the most likely case- I can service the deck if you want at Skywave Tape Deck Repair Chicago area. I will most likely put a new motor into the deck.
Oct 04, 2010 | Teac V377 Single Dual Cassette Deck
Tascam 644 When I press play it won''t stay on play, it stops. It will rewind and fast forward but that too stops by itself.
Scott has a point. You need to determine what is causing the unit to stop and it could be a bad cam motor belt if it has one or the lack of take-up die to the bad idler or even a dead spot on the reel motor. The reel motor will work normally at high speeds due to inertia but at low speeds as are used in play the dead spot of the motor can become much more apparent.
Sep 17, 2010 | Tascam 122MKIII Single Dual Cassette Deck
RS-TR272 dual deck and capstans seem to be locked in both decks. When you try to play a tape the take up reel does not turn. Can not get fast forward or fast reverse to work. How to fix and is it worth...
DO NOT spray anything into this unit. The problem is a slipping belt and is a simple fix for any audio shop. While possible, it is rare for a motor to fail. There is a small belt that drives the take up side along with a felt clutch assembly that can slip. If this is the case, the unit will realize that the take-up reel is not turning and shutdown the unit. Please have this serviced. The belts will run around $6-$10 total.
Dan
Nov 05, 2009 | Technics RS-TR272 Single Cassette Deck
TEAC 2000R SITTING FOR WHILE NOW WILLNOT PLAY
This sounds like the solonoids are not working. This can be a power supply problem, a control problem, or the solonoids themselves. In any case, this will need to see a service shop. Where are you located?
Dan
Aug 16, 2009 | Teac Audio Players & Recorders
 Grubhead
Grubhead
Marvin
Marvin
