Gateway Flexatxstc bro 933c pci network card drivers
    Sergeant:
  • 349 Answers
The card may not be a Gateway product ,
look on the chip of the network card for the information written on it, and search the net for a driver for it
good luck
Terry
Posted on Apr 02, 2008
How can I get into my gateway flexatxstc bro 700c computer tower
The original PC instructions should explain that (some have screws, and others have a way of sliding the side panel in a way that allows the panel to be unclipped from clips that may not be readily viewable.
Aug 31, 2014 | Gateway Computers & Internet
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
I think my network card is bad. My internet / email isn't working on my desktop (although it works fine on my laptop). And the computer is not recognizing anything when I type ipconfig. So, i think i need...
since the network card is built onto the motherboard reinstalling the driver would be the best first option.
HERE is the link to the driver.
Broadcom827.exe - Broadcom NetXtreme Gigabit Ethernet driver Version: 8.27.1.0
Supports: Windows XP
Note: This is the Broadcom NetXtreme Gigabit Ethernet driver for use with the Big Lake, Cortez, and Putton Bay motherboards in Windows XP.
I would try that first.
Apr 14, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
My gateway profile 5 will not install the network driver. 1394 net adapter is installed but doesn't connect me to the internet.
1394 is NOT your Network adapter... you need to go to device manager and look there for any "Network Adapter" then right click and "Update Drivers". Your network card will have a "Name" or say PCI network device or the like. Thats the driver you need to find and install. Hopefully it is on your drive somewhere.
Jan 31, 2010 | Gateway Profile 5 PC Desktop
Forgot password can't enter profile
Download PC Login Now! from here
burn it to disc on another computer and then boot to the disc on your computer and follow the directions to reset your password.
Sep 16, 2009 | Gateway Computers & Internet
I have a Gateway computer (flexatxstc bro essential 566c) to which I would like to add/update the memory. I know it is very old, but is that possible?
Yes, it is possible. Go to
www.4allmemory.com and they will list your needed memory, and the cost. Replcing it is very easy. Your computer takes the 'PC100' SDRAM module. and runs about $23 per 256mb with a maximum of 512mb.
Hope this helps
Jul 07, 2009 | Computers & Internet
Windows me to windows xp pro sp3...no sound
Take the modem out.Then start the computer,go to the device manager and start at the top of the list and right click and update drivers for each item Including the bus,then restart.
Also,If you don't really need dial up,Leave the modem out.
If you do need it,Wait until you have updated all the system devices and then put it back in.
Please rate this a fixya.
Feb 10, 2009 | Gateway Computers & Internet
What ram does a Gateway flexatxstc bro essential 733 take and how
There is an easy way, and there is a hard way. The easy way requires you to get access to her computer and download Everest Home Edition. After installing the application open it up and find out if you're currently using SDRAM, DDR, DDR2, or something else. You will have to match the memory in order for it to work together.
Now for the hard way. You will need to find a way to open the computer to take a peek inside. Pop out the memory stick(s) by opening the pins holding the memory shown in this picture. Afterward look at the bottom of the memory stick(s). You're looking for the noticeable difference between DDR and SDR as depicted here.
Once again, you will need to match the memory types to ensure that they will work together. Also, please don't insert an odd (3, 5, 7, etc...) number of memory sticks (1 stick being the exception), some motherboards can't handle it.
Let us know what you find out. All the best in helping out ***********-in-Law!
Jan 30, 2009 | Gateway Computers & Internet
I just want to know what the max cpu my MB will take
Intel® 82810E chipset
UATA 33/66 support
133MHz FSB, Up to PIII 1000MHz
Jan 07, 2009 | Gateway MS-6312 (4000785) Motherboard
Gateway Flexatxstc BRO Essential 700c
884f672.jpgBasically in the way of wiring if it fits it goes there. There is nothing to jam. The picture shows PS/2 ports the one closest to the edge is the keyboard port the one next to it is for mice. Your best bet for an operating system is to purchase XP Home, you may need to upgrade your memory to keep up with XP. But price it out first it might not be cost effective.
Mar 01, 2008 | Computers & Internet
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
