Question about Canon PowerShot S2 IS Digital Camera
Canon S2IS Black Screen in Auto mode
I'm having a problem with the CCD not working when I start the camera. I have to turn it on and off repeatedly to get a image on the view screen in camera mode. Also, when I get it working the images are dark until I restart it one more time. Same thing with video, images have a dark orange cast then advance to a blue hue. HELP!!!!
  • vodick Apr 12, 2008
    My screen and viewfinder is black when turning camera on. I can see images but cannot shut.
    Vlad
  • 104 Answers
Sir, ur problume related to CCD u replace CCD
Posted on Apr 11, 2008
My s2is powershot camera works fine but it seems the lens will not open there is nothing in the view finder, it takes picture but it is black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 18, 2010 | Canon PowerShot S2 IS Digital Camera
Display
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 30, 2010 | Canon PowerShot S2 IS Digital Camera
I cannot get anything to appear on my LCD display or view finder other than menu information. Is this a setting or is there a problem with my Canon S2IS camera?
Feb 20, 2010 | Canon PowerShot S2 IS Digital Camera
When turn on camera on screen is black
I think your Canon A70 camera does not show live view in camera mode to take pictures but show you previously stored picture properly in playback mode.
If that is true then Canon A70 camera got problem of bad ccd imager that will be replaced to get live vew in camera mode.
Canon will replace ccd imager for free, click Canon CCD Imager Advisory for details.
Thanks.
Sep 23, 2009 | Canon PowerShot A70 Digital Camera
LCD monitor is black
Sep 07, 2009 | Canon PowerShot SD890 IS Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Black screen
Sounds like you have a bad CCD. You can try contacting Canon to check out your options on how to get this repaired. Unfortunately the S2IS is not on their CCD recall list of cameras.
Mar 06, 2008 | Canon PowerShot S2 IS Digital Camera
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
