No service I disconnected a cable box and tried to connect another one but it did not work so I reconnected the old one now I get no service on the tv screen I do not the directions for the tv they were not in the box when I bought it. Thank you please help
  • stoli Apr 02, 2008
    Thank you so much that was very helpful My tv is working fine. Thanks again
    Sergeant:
  • 247 Answers
  • Make sure that you have connected the cable box properly to the TV.
  • Use the audio and video OUT from the box to the TV IN.
  • Select the correct input on the TV.
  • Connect it using any of the following: A HDMI cable (1 cable for both audio and video), Component Cables (3 RCA's red, green, blue) + RCA audio cables (1 for mono or 2 for stereo), S-Video + RCA audio cables (1 for mono or 2 for stereo), or AV cables - 1 RCA for video (usually marked yellow) + RCA audio cables (1 for mono or 2 for stereo).
  • Consult your TV's owner's manual for detailed instructions or ask me for more information.
Hope this helps. :)
Posted on Apr 02, 2008
+why is my tv saying no signal when it is hooked up to cable
Try the old electronic trick of switching all OFF and removing the plugs to TV and cable box for five minutes then reconnect.
I have found in the past this works !
Nov 27, 2014 | Vizio VA19LHDTV10T 19 in. LCD TV
Why does my monitor start as white when I turn it on? THe mouse pad does not work as well.
Monitor cable disconnected internally?
follow http://www.insidemylaptop.com/replace-screen-on-dell-latitude-e5420-laptop/
and disconnect, clean and reconnect ALL monitor related cables. (You may need a new screen if that fails)
You may check your laptop by connecting an external monitor first.
Aug 21, 2014 | Dell LATITUDE Computers & Internet
White lines on screen after reconnecting Directv D12-100 Box to TV
d12-100 box does not have an hdmi port what it does have is a problem the signal level coming out of the box is to high install a 4 way splitter between the box and the tv line out of the box to the in of the splitter any port out of the splitter to the tv the problem you are having is called ghosting
Feb 22, 2012 | Directv D12-300/100 DTV Receiver
When I connect my Panasonic PT-43LC14 to my cable box using an HDMI cable I get a green screen. I can hear the sound, but no picture. When I connected my Blue-Rey player the HDMI port worked fine.
U have a old version of firmware in ur cable box or ur cable pakage don't have HD service.Tries find out if ur subcribe package have HD serviced and trade in ur old cable box.Not ur tv or a cable box malfunctions.
Jun 12, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Turn on tv have sound and picture then screen turns blue no picture but have sound
Blue screens are a strong hint that your tv isn't picking up an image. Check to see if you have a firm connection on both your tv and your input device (cable box/ dvd player). You may want to disconnect and reconnect fully. Also attempt selecting other inputs. If you only have trouble with that one input, then you have a loose internal connection. Also make sure that your TV can display an image by trying to use the on screen controls.
Sep 05, 2010 | Sony KP-53V75 53" Rear Projection...
Our big screen sony tv stopped working yesterday. The power on light is blinking red intermittently and when you push it, it doesn't turn on-no sound or picture. It will stop blinking red periodically, but...
Please try disconnecting all the cables from the TV including the power cables then reconnect them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then service will be required.
Aug 27, 2009 | Sony Televison & Video
My 6 month old tv went out during a movie we were watching and when i turn it back on all i get is a blank black screen. what do i do? It is a 42" Element
Hi Chris!
Please disconnect all the cables from the TV then reconnect them back after two minutes. Make sure that the power cable from the TV is directly connected to a functional wall outlet. Next, turn ON the TV and reset it to the original factory settings. You may also try connecting a different video source such as cable box, DVD player, Blu-Ray player, Playstation, etc to the TV to check whether the issue persists with all the video sources.
If the issue persists with all the video sources then service may be required.
Jul 12, 2009 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
Jun 03, 2009 | LG 42LG30 42 in. LCD HDTV
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
