Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
Beeping I have had this fan for less than a year and I went to turn it on today and it just started beeping at me. Not working at all just beeping. I unplugged it and the beeping slowly died off. Can you tell me what is wrong?
  • davstf Apr 19, 2008
    Lasko 4820 tower
    I have this fan about a year. This spring I attempted to turn it on, but all it does is beep, no lights, no fan, nothing except of course for the incessant beeping
  • Anonymous Dec 03, 2008
    I can't believe a google search actually turned up someone else with same problem. Any ideas? no mention of this in instructions or on their website
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
Frigidaire lra157mt1
Some of the new style Air conditioners have a auto time delay built into them for power failures. If power fails or you unplug the unit, they will not come back on for about 3 to 5 minutes. This is a safety feature to keep power failures from damaging the compressor. Keep it plugged in for 5 minutes and try again. If still no go then call for service. You should have a 1 year warranty on it.
May 27, 2012 | Frigidaire Heating & Cooling
I have a macbook that is a year and 1/2 old. i went to turn it on today and the screen stayed black and it makes loud beeps. why is this happening?
Does it should be the battery or adapter for MacBook have some matter?Oh,it shouldn't be, it must beause the Fan of CPU or Other Fans of your MacBook Motherboards will wear out! You'd better clear and maintain it.
Dec 14, 2010 | Apple MacBook PC Notebook
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
I have a Frigidaire GLEQ2152ES 5.8 cu front-loading dryer. For the past year I have had no problems. Today I went to put in the first load and when I tried to start it I got nothing but 3 beeps. Even...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 29, 2010 | Frigidaire Dryers
I have a Dell Vostro 410; beeping and beeping!!!
plz check its a ram or pheriphals u pluged is wrong.
Nov 14, 2009 | Computers & Internet
REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Emerson CF4800 with SW375 receiver that does not turn on fan!
Please excuse me if you already have the answer, but I went thru the same thing and found that the actual receiver was broken. The receiver that is found in the top part of the fan itself. I was able to diagnose the problem because I have two of the same fans in the house and when I switched the receiver units, the broken fan started to work. Hope that helps.
May 30, 2009 | Emerson Fans Emerson SW375 Receiver
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
193 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
