Question about Alpine IVA-D901 Car DVD Player
Doesn't respond to any buttons, delayed power on
Just recently, my iva-d901 stopped responding to any of my input. it does not respond to button pushes, only screen opening and closing. on a cold start, the headunit takes about 3mins to power on, and still does not respond. i have tried the reset button, unplugging the power and plugging back in, nothing so far has worked. any help would be greatly appreciated, thanks in advanced.
I am having the same problem. Did you find out an answer? Thank you.
Posted on Mar 22, 2010
How do I fix my new TV which will sometimes lock up and will not respond to some buttons on the remote or the TV itself?
it is under 1 year warranty from the manufacturer,contact them for repair,they will send someone to you
May 24, 2015 | Televison & Video
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
My Sony vaio pcg 3c2l has locked up. The keyboard stopped responding and now the screen is black, but the power light is still on. The power button doesn't respond when I push it. What should I do?
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 05, 2011 | Sony Computers & Internet
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
My G5 2.0 dual core has recently stopped responding to the eject button. I have restarted. It does respond the the eject button in Toast... Any ideas?
Repair the permissions. <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/SgcYuH-Fpas&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/SgcYuH-Fpas&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Oct 23, 2009 | Apple iMac G5 Desktop
Delay in responding to buttons
I have similar situation where mine started freezing for no reason.. I suspect faulty battery.. May need replacing and possibly, recall of battery.
Nov 09, 2007 | Samsung SPH-M500 Cellular Phone
Alpine IVA-D901 Car DVD Player Logo
150 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
