Question about Samsung i760 Black Phone
Screen freeze after soft reset
My screen freezes after 2 soft resets I have to perform a hard reset and the problem persists. what application can cause this ? or how can I solve this problem ?
  • marquina Apr 02, 2008
    I already removed the battery and the SD card. After restore and a hard reset I can complete only one soft reset after that the second soft reset the pocket pc freezes. I have Samsung I760 WM 6.
    how can I install the firmware in my pda phone. Only opens in the computer
    Genius:
  • 1,226 Answers
Hello
did you remove the battery ? Shut off it and the remove the battery some freeze can be resolve like that. if not may be you need to update the firmware of the phone.
melnavz
Posted on Apr 01, 2008
6ya staff
SOURCE:
Ipaq 111 hard reset
Soft reset Perform a soft reset
A soft reset stops all running applications, but does not erase any programs or saved data.
NOTE: Be sure to close all running applications before performing a soft reset.
To perform a soft reset:
1. Locate the recessed Reset button on the HP iPAQ.
2. Use the stylus to lightly press the Reset button.
Hard reset
To perform a hard reset and return the HP iPAQ to factory settings:
Press Win + OK + Record together.
While doing that, press reset button and hold for 3-4 seconds.
Release reset.
Release buttons.
NOTE: Do not release the buttons until CLEAN REBOOT appears on the screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | HP iPAQ 111 Classic Pocket PC
Tip
How to reset your Blackberry
Performing a soft reset stops all applications on the BlackBerry device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between the BlackBerry device and the computer.
Performing a double-soft reset stops all applications on the BlackBerry device and is nearly the equivalent of a hard reset. Timing however is critical. Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass.
The first step in troubleshooting a networ, software or hardware error is often to perform a hard reset. With Java® based devices, this is accomplished by removing the battery, while the BlackBerry device is powered on. Hold the battery out for about 30 seconds, and replace. The BlackBerry device will reboot.
on Apr 17, 2010 | Cell Phones
Tip
IPhone soft reset
When you use your iPhone, as timegoes on, you will notice that it develops a few operational errors like application or startup errors, sometimes the iPhone may freeze.
This happens as a result of the system files geting corrupted.
To solve this problem you can perform a system reset of your iPhone.
There are two methods of resetting your iPhone, there is a soft reset and a hard (factory) reset.
The soft reset will not erase all your data but it will erase your resent data, so it is important to back up your files before performing the soft reset.
After you have performed the backup, follow these procedures to perform an iPhone soft rese:
1. Bring up iTunes.
2. Connect your iPhone to the computer, ( let it come up in its loop ).
3. Press and hold the power button and the home key simultaneously.
4. Keep these pressed until the screen goes off, then release the power button but keep pressing the home key.
If it does not work the first time, repeat it. iTunes will eventually detect that there is a device in reset mode and ask if you want to reset, hit yes and hopefully you will be able to get out.
If this does not solve your problem, you will have to perform a factory (hard) reset, which we can look at in my next tip.
Thank you for using Fixya,
Kenneth.
on Apr 10, 2010 | Cell Phones
Can you fix my low on memory palm centro. It erased all of my photos and won't take new ones. It says momory is too low. Can you fix?
hi,
you have to reset your phone in order to fix that..but you have to save all your important data before you do the reset...here is how..
Performing a soft reset is similar to restarting a computer. If your Centro device is not responding or you're having trouble synchronizing with your computer, a soft reset may
help. All your information is retained when you perform a soft reset.
1. Remove the battery from your device, and then reinsert it.
Note: The reset begins when you insert the battery and ends when the
Date & Time Preferences screen appears.
2. Select Done.
Replacing the Battery
Your Centro device comes with a replaceable battery. Be sure to use a battery that is approved by Sprint and that is compatible with your device. Failure to use the proper
battery may result in personal injury or product damage, and it voids your device warranty.
1. Press Power/End palm_centro_hard_reset_soft_reset_2.jpg to turn off the screen.
2. Gently press down on the Battery Door, and then slide the door downward to remove it from your device.
3. Place a finger in the notch next to the battery and lift the battery up at a 45-degree angle to remove it from the compartment.
4. Align the metal contacts on the new battery with the contacts inside the battery compartment.
5. Insert the new battery into the compartment at a 45-degree angle, pressing it into place. Slide the battery door onto the back of the device until it clicks into place.
6. Connect your device to the charger or sync cable.
7. Wait for your device to turn on, and then enable the network time or set the date and time when prompted.
System Reset
A system reset, also called a safe or warm reset, can be useful if your device loops or freezes during a soft reset. Performing a system reset allows you to get out of the loop and restores limited functionality to your device in order to uninstall a third-party application that's causing the problem. Note that after a system reset, you must perform a soft reset to restore full functionality, including the wireless features, to your device.
1. Remove the battery from your device.
2. Press and hold Up palm_centro_hard_reset_soft_reset_3.jpg on the 5-way palm_centro_hard_reset_soft_reset_4.jpg while reinserting the battery.
3. When Date & Time Preferences appears, release Up palm_centro_hard_reset_soft_reset_3.jpg
4. Delete the third-party application that you suspect is causing the problem.
5. Perform a soft reset. (The wireless features of your device are not available until you complete this step.)
ard Reset
A hard reset erases all information and third-party software on your Centro device. Never perform a hard reset without first trying a soft reset and a system reset. You can restore previously synchronized information the next time you synchronize.
A hard reset can tell you if a problem stems from your Centro device or from an application installed on it. If you do not experience the problem after you perform a hard reset, the problem is related to software you installed.
Important: If you set a password on your device, performing a hard reset reformats your device (the message "Reformatting in progress" is displayed). This is a more severe form of a hard reset, which removes all your information and restores your formats, preferences, and other settings to the factory default settings.
Note: Some third-party applications do not create a backup on your computer when you synchronize. If you perform a hard reset, you may lose data in these applications and you need to reinstall these applications after the hard reset. Please contact the developer to find out which information is backed up during synchronization.
i hope it will help you..thanks for trusting fixya
Jan 31, 2011 | AT&T Palm Centro Cell Phone - White
Need to get back a default software/application but how?
Resetting the BlackBerry device is a useful way to resolve issues and is usually the first step in troubleshooting the BlackBerry device. Knowing the differences between a hard, soft, double-soft, and master reset ensures that the correct troubleshooting method has been chosen. Note: Backup all applications before resetting the BlackBerry device using the Backup and Restore tool on the BlackBerry Desktop Manager.
Please follow the below steps or resetting
Performing a SOFT reset on the BlackBerry device Performing a soft reset stops all applications on the BlackBerry device by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. A soft reset re-establishes communication between the BlackBerry device and the computer.
Note: This does not apply to the BlackBerry® Pearl™ smartphone.
Performing a DOUBLE-SOFT reset on the BlackBerry device Performing a double-soft reset stops all applications on the BlackBerry device and is nearly the equivalent of a hard reset. Timing however is critical. Perform a soft reset by pressing the ALT+RIGHT SHIFT(CAP)+DELETE keys. The screen will go blank. When the screen is no longer black, press the ALT+RIGHT SHIFT(CAP)+DELETE keys again. You should then see another blank screen followed by an hour glass.
If you liked my response Please do Rate this solution.
May 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Freezing
You have likely installed some application that is interfering with phone. Start with latest application you installed, then gradually uninstall all application you added to phone till problem is fixed. To view and uninstall applications, go to Start/Settings/Remove Programs.
If you have no luck with this, then Hard Reset your phone. You can do a Hard Reset which will reset your phone to its original factory settings. Any applications or personal data you put on the phone since owning will be lost. You can recover personal file if you have backed them up, of if you have License 'Key' numbers you got when you purchase them. Some App suppliers will have you an record and will email your Lic # if your email has not changed since purchase.
To Hard Reset, turn off your phone and then turn it back own while holding down both left and right soft keys till you get a screen asking if you want to Reset it. Another Hard Reset method, if you can get to Start Menu/Accessories folder when phone is powered, is choose Clear Storage and clear the storage. This may not work on some phone models, but note this method will also reset your phone to 'as purchased' state, with all stuff you added since removed.
Note a Soft Reset is the same thing as just turning phone off then back on as normal. It does nothing but re-power your phone, but a Hard Reset recovers your phone operating system from phones MFG ROM and resets it back to original as purchased state.
Jan 13, 2009 | Orange SPV C500 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
The Pocket PC restarts and displays the Today screen.
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Oct 16, 2008 | Computers & Internet
API call to enable WiFi freezes screen
Here at Legacy Global we can help you. Call Diana at 1-847-750-9231.
Jul 15, 2008 | Symbol MC70
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
Samsung i760 Black Phone Logo
111 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
