Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother mfc 240c
I had a paper jam and now my printer prints everything unaligned I tried the alignment but none resemble the one it's suppost to.. there has to be sometnig I can move to make it right again. Please help. thanks
  • 832 Answers
No. there is another alignment which can only be done by sevice personell. you have to take the machine to a service partner.
Posted on Apr 02, 2008
My brother mfc 240 c is keep saying paper jam but we have move the cover and we do not see a paper jam how do we resolve this issue please help
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum. get more information to fix brother mfc printer paper jam problem .
Jan 24, 2011 | Brother Multi-Function Center MFC-240C...
I have brother MFC_240 which after paper jam not printing
My MFC-240C has the same problem. Sometimes you have to turn the printer off and then turn it back on after a paper jam to get it to print again.
May 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
My mfc 240c always shows paper jam, and nothing found
please printer in open the head couver and check the paper and other
small parts paper in printer and you carteriase out of printer and
check the paper and printer in back side in fixes paper to out and
clean the printer and close the couver is ok and apply the plug printer is on and aply print ok
Sep 15, 2009 | Brother Multi-Function Center MFC-240C...
Glossy paper jams
hello! most printers will only print on regular , you can not use glossy paper. the paper pick up rollers will not grab the paper, they tend to skid on the paper, good luck. brother tech
Jan 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
My Brother Multi-Function Center MFC-240C All-in-0ne Paper Jammed
how i can i plug mymulti-function center mfc model mfc240c to my pc
Dec 08, 2008 | Brother Multi-Function Center MFC-240C...
Paper jam then not printing
TRY OPENING THE BACK DOOR AND TRY RESEATING THE PAPER SENSOR
Dec 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
How to solvc machine error 50?
sounds like you have print error. if it under 1 year, yyou still have warranrt, then take the machine to a service center brother tech. ps you can not do this by yoursekf!
Nov 22, 2008 | Brother MFC 240C All-In-One InkJet Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
140 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
