Question about Whirlpool LER5636P Electric Dryer
Dryer door will not stay closed
My son stood on my dryer door that opens from the front and now the door of the dryer will not stayed closed. is there anyway to fix this without buying a new dryer or having to keep putting something heavy infront of the door to keep it closed? please please help
  • Anonymous Mar 18, 2014
    model # WTMC3300US/01 DOOR WILL NOT STAY CLOSED
    Scholar:
  • 178 Answers
Door will not lock light stays on
Usually this is caused by the door being bent, the hinges being bent, or a worn out door strike/catch not holding the door tightly closed. Lol, got kids?? Mommy's little helpers love to lean on the doors(the ones that open/close vertically). Also, slamming the dryer door can break the little plastic arm attached to the door switch--I see MANY switches with the arms broken in-half or the strikes/catches damaged from slamming. Usually a relatively simple repair to replace the strike/catch.
Aug 13, 2015 | Kenmore Dryers
Cannot get dryer door to close/latch properly.
Hi stay at home MOM
  1. what is the Model of Dryer?
  2. do you pull to open or push button to open DRYER Door?
  3. hinges on the right or the left?
  4. door inner n outer panels plastic?
  5. is there a door seal on the door?
  6. when you did your removal of lint, did you remove DOOR?
  7. picture front of dryer area and door of dryer will help.
Sep 27, 2014 | Dryers
Dryer door won't stay open while removing clothes
Likely the feet to the dryer are not level. Grab a large level and check to ensure the top front is level across.
If your door opens to the right, raise the front left foot by screwing it counterclockwise. Check level, and repeat.
Mirror the operation for a door that swings to the left.
Jan 25, 2012 | General Electric WCVH6400J Front Load...
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Dryer won't start; light stays on whether door is open or closed.
Sounds like the door switch is not functioning or shorted......in other words the dryer thinks the door is open so it won't turn on.
Jun 22, 2009 | Dryers
Door does not stay closed
your door clip needs to be replaced or realign
your door
Jun 11, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer door won't stay closed
hi,
shut off the breaker- pull the female receptacle clasp out of the front with flat screwdriver and needle nose and squeeze the back of it gently with pliers, replace, if its busted and you get mad, you can buy a standard padlock and latch and install that, that helps in other ways as well, careful to steer clear and watch the inner wall for wires and clearances if your going to retrofit that.
J
Jun 17, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
274 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
