Question about Maytag PYE2300AY Electric Dryer
MAYTAG PERFORMA PYET244AYW
Our dryer quit working sometime in the first 20 minutes of drying time. I walked by and noticed a burning smell and that the timer was still going but the tumbler was not tumbling. I shut it all off and told my husband the next day. He was about to by a new dryer when I gGoogled our model number and found some advice about replacing the heating element. So...he ordered one for $23.95. It arrived today. He installed it. We turned it on with some wet towels in it. It worked! ...for about 3 minutes and then it just stopped. The top of the dryer was too hot to touch. We are wondering if this is a thermostat problem?
  • humberguy Oct 07, 2008
    i got the same problem with overheating but i did changed my thermal fuse. The dryer ran for about 10 min but was overheating again and blew the fuse again. What can my problem be?
Hi, can maytag performa dryer (Model:PYET244AYW) can be converted in to propane gas system?
Posted on Oct 16, 2011
    Scholar:
  • 178 Answers
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Posted on Apr 02, 2008
Dryer smelling like eletrical burning and not working properly
if dont have warranty to be on safe side i junk it. usally to risk to fix thoes things
Dec 29, 2012 | Maytag Dryers
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
My Maytag Performa PYG2300AWW dryer quit working today. 1st we noticed it wasn't dying clothes, then there was a smell. We thought the lint was clogging it up, so we vacuumed everything out. Now it won't...
This could be the thermal fuse or Hi Limit thermostat possibly a few other components. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting procedure. It's a different model but testing and components are the same.
Mar 27, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
Feb 24, 2010 | Maytag Performa PAV2200
My 8yr old Magtag PYET244AYW dryer is getting worse...
check the air flow at the exhaust,
you should have a good and steady flow while the dryer is running.
sometimes cloggs happen in the middle of the exhaust line
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa gas dryer no longer produces heat.
needs a new timer switch sometimes cheaper to buy another dryer (used)
Dec 02, 2008 | Maytag Performa PAV2200
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Maytag PYE2300AY Electric Dryer Logo
1,159 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
