Question about KitchenAid 27 in. Built-in Microwave/Convection Oven
Kitchenaid Superba 27 built-in Microwave/Oven
The red light and fan starts without anyone touching the controls? I think it must be a ghost - I have turn it off by turning off the main power and let it remain off for about an hour, turn it on and it's OK for about 45 minutes and without touching anything the red light and fan start again. Can you hep me.
Thank You,
Garry Bass
[email protected]
or
[email protected]
  • DaddyB Apr 04, 2008
    I turned the power off ALL Night - I turned the power on , reset the time and it worked fine for about an hour or so and the red light came on and the fan turned on, again I did not touch anything. The on switch is a dial type switch. When I try the switch It works like it is supposed to do - On/Off whenever it is turned to the appropriate setting.
  • KitchenAid Master
  • 19,396 Answers
Disconnect it from power outlet for 30 minutes to hard reset the owen. It may be a faulty control panel or the fan thermistore switch.
Posted on Apr 02, 2008
SOURCE:
What does errer codes E6 and F2 on KitchenAid Superba oven mean
From the Site:
"F2-E6 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly. All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD)."
Kitchen Aid Appliance Fault Codes
Hope this helps!
Anthony
Mar 17, 2018 | KitchenAid Ovens
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
I have a KitchenAid Superba KEMC308KSS0 that is about 9 years old. In the past few months it has been cooking really slowly. Whereas in the past, in convection mode, things cooked faster than...
I have a Superba built-in YKEBS 177 D56 ( dual convection/convention)...I think it might be about 10 years old. I noticed the same thing starting last year..the temperature seems a litlle off and the cook time on the convention seems to take longer. I've never used the conventional oven so I don't know if the temperature is OK on that component.
I don't have a manual. and I've been searching for it...does anyone know which one I need?
Sorry I couldn't help with your problem, mine is similar to your though!!
Jan 22, 2011 | KitchenAid KEMC308K Double Oven
Can we light a gas oven manually, it is a kitchenaid superba
No, You have to replace it. When the ignitor grows weak, it does not allow enough voltage through it to open the gas valve. Very common problem. Good Luck, Appliance Specialists
Jan 31, 2010 | Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
What would cause the microwave oven to go out other than the power?
The magnatron is cooked or timer and/ or wire inside. If it is older, buy a new one. The repair cost on it is not worth it. Proabally over 100 bucks to start
Oct 20, 2009 | KitchenAid 27 in. Built-in...
Kitchenaid Superba 27 KEMS376WHO
Go to manualsonline.com. They will ask for make and model of your appliance. Most manuals are free. Give it a try.
Jul 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
KitchenAid 27 in. Built-in Microwave/Convection Oven Logo
999 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
jdthefixer
Colin Stickland
Colin Stickland
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
